Frame touch up paint - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Frame touch up paint (/showthread.php?tid=63168) |
Frame touch up paint - Fazer Jake - 30-04-13 Few areas of my frame need attention, anyone found a good match to the original paint@? Re: Frame touch up paint - Chris - 30-04-13 I've used gloss/smooth black hammerite before to touch in bits that have chipped etc and it's worked fine. Chris Re: Frame touch up paint - JZS 600 - 30-04-13 I was thinking the same, especially if it's out of the way like under the tank/head stock area Re: Frame touch up paint - Chris - 30-04-13 Ye, where abouts are the ares you want to touch up on the frame? If it is really obvious places, i'd take a good amount of time to mask off things around it and spray it but if it's hidden away and you just don't want it to rust then a fine brush should be fine. Chris |
