Side play in gear pedal 03 Foxeye - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Side play in gear pedal 03 Foxeye (/showthread.php?tid=63103) |
Side play in gear pedal 03 Foxeye - Dave48 - 26-04-13 There is considerable side play between the pedal & footpeg shaft. Havent yet removed footpeg from alloy holding plate as bolt is corroded in. Does anyone know if the pedal hole is fitted with a bush or just steel drilling operating on steel shaft? Have looked at my thou and there is hardly any lateral movement of the pedal resulting in nice slick changes. Guess I will be trawling ebay for a replacement as I cant stand a sloppy gearchange! Re: Side play in gear pedal 03 Foxeye - darrsi - 26-04-13 Agreed, nobody likes a sloppy 2nd :lol Re: Side play in gear pedal 03 Foxeye - Fazerider - 26-04-13 Assuming it's the same as the earlier version, it is just a plain steel hole. I added a steel washer to the shaft to cut down on the free play where the lever (and wafer thin spring washer) wears against the alloy hanger and also a rubber 'O' ring to try to keep rain/grit out and grease in. It's helped, but has now done about 80k so the lever and pivot could do with being replaced again. Re: Side play in gear pedal 03 Foxeye - Dave48 - 26-04-13 Update-managed to disassemble footpeg to discover the remains of a very thin wave washer that alledgedly takes up end float. have cleaned regeased and fitted thin washers either side of pedal shaft. Not perfect but more like a bike gearchange than a car now! Will replace worn parts in due course. :lol Re: Side play in gear pedal 03 Foxeye - unfazed - 26-04-13 I had the gear lever hole enlarged and a steel sleeve made to suit, fitted a new wavy washer and all was fine again
