bike not starting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: bike not starting (/showthread.php?tid=63093) Pages:
bike not starting - yamy - 25-04-13 Hi all I'm in need of some help, I've changed the starter relay, starter and button to no good as to why it's not Starting without abump start ? any ideas what it could be? Re: bike not starting - darrsi - 25-04-13 Bit more info needed, does it turn over using the button, is the battery okay, etc Re: bike not starting - yamy - 25-04-13 hi when button is pushed there's nothing (no clicking etc) Battery is fully charged. Re: bike not starting - riz - 25-04-13 Try starting with the clutch in Re: bike not starting - Orangegrump - 25-04-13 Check the position of the red cut out switch on the right hand handle bar Re: bike not starting - yamy - 25-04-13 Just tried all above and still nothing Re: bike not starting - Dead Eye - 25-04-13 Time to check for bad connections to the starter motor. Use a multimeter and see if you are getting power whilst thumbing the starter button Re: bike not starting - John Silva - 25-04-13 Have you checked all the fuses. Re: bike not starting - yamy - 25-04-13 All fuses checked and are ok.all wires feel fine. Just thinking could it be the immobiliser playing up but starts with bump through. Cheers Re: bike not starting - yamy - 25-04-13 is there a fuse just for the starting ? apart from on the relay Re: bike not starting - yamy - 26-04-13 Just a update just been out to it and it started first time Re: bike not starting - Ruby Racing - 26-04-13 So perhaps you have an intermittent problem? Now that's the worst kind.
Re: bike not starting - clayt74 - 26-04-13 (26-04-13, 09:09 AM)Ruby Racing link Wrote: So perhaps you have an intermittent problem? Now that's the worst kind.A bit like when I asked the missus if my indicators worked and she stood watching sayiny yes......no........yes.....no........yes :lol Re: bike not starting - Exupnut - 26-04-13 Lmao hahaha Re: bike not starting - Fazerider - 26-04-13 As always, it can be a broken wire or corroded connector, a careful visual check of the bundle in the plastic box under the tank and by the battery compartment may show the problem. Otherwise it could be the starter cut-out relay. Re: bike not starting - yamy - 26-04-13 (26-04-13, 05:26 PM)Fazerider link Wrote: As always, it can be a broken wire or corroded connector, a careful visual check of the bundle in the plastic box under the tank and by the battery compartment may show the problem. Otherwise it could be the starter cut-out relay.cheers bud but where is the starter cut out relay Re: bike not starting - Fazerider - 26-04-13 (26-04-13, 09:02 PM)yamy link Wrote: [quote author=Fazerider link=topic=7470.msg72020#msg72020 date=1366993563]cheers bud but where is the starter cut out relay [/quote] It's near the starter relay, lift the seat and take the left hand side panel off, it's the one with a connector with 11 wires. Re: bike not starting - yamy - 27-04-13 Cheers bud will look at it and see what's going on Re: bike not starting - yamy - 27-04-13 Looks clean but got one on order now 15 quid Re: bike not starting - Fazerider - 27-04-13 Hope that solves it. I would have poked around with a multimeter to check it's faulty before splashing out... but I am a skinflint. :lol |
