outer race of front wheel bearing stuck in hub - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: outer race of front wheel bearing stuck in hub (/showthread.php?tid=63072) |
outer race of front wheel bearing stuck in hub - Robfzs - 24-04-13 tried everything, dremel slot, chisel/ punch, heat gun, hammering, got a little bit of it off, but by now if it was normal it should have peeled off, so it must be welded to the hub, any ideas to remove it ? thanks Re: outer race of front wheel bearing stuck in hub - Gnasher - 24-04-13 Where did you apply the heat with the heat gun? Re: outer race of front wheel bearing stuck in hub - griff86 - 24-04-13 I used the dremel aluminium oxide grinding stone and cut away one part of the outer race which made it easy for it collapse into itself. |
