HELP NEEDED - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: HELP NEEDED (/showthread.php?tid=62988) |
HELP NEEDED - Young rider - 19-04-13 [color=rgb(68, 68, 68)]went to take my exhaust off as they needed someone tlc and i manage to snap one of the bolts off.[/color][color=rgb(68, 68, 68)][/size]is there anyway or anyone who can help get it out? [/color]
Re: HELP NEEDED - Dead Eye - 19-04-13 Nasty, its one of the awkward ones as well... cylinder 2 is an absolute b!t*h compared to the others... Best bet is a decent stud remover - with the radiator off (and maybe the forks + front wheel) you may be able to get to it. Otherwise its either engine out or head off... I'd help out, as I had to do this myself earlier this year but I'm nowhere near you
Re: HELP NEEDED - Young rider - 19-04-13 (19-04-13, 09:39 PM)Dead Eye link Wrote: Nasty, its one of the awkward ones as well... cylinder 2 is an absolute b!t*h compared to the others... Do you think welding a nut too it and spraying wd40 on it, as the heat should be able to loosen it? Re: HELP NEEDED - richfzs - 19-04-13 Not wd40, as it's not penetrating fluid. Use either plus gas, or one of the other proper penetrating products out there Sent from my Nexus 7 using Tapatalk 2 Re: HELP NEEDED - Young rider - 19-04-13 I'm gonna buy the extraction tool tomorrow see if that moves it. Don't wanna cause more damage. Re: HELP NEEDED - Fazerider - 20-04-13 Heat is often useful, the aluminium expands more than steel and loosens its grip, but the heat from welding a nut on would be a bit extreme and risks cracking the casting. A hot air gun and penetrating fluid should help though. Re: HELP NEEDED - Dead Eye - 20-04-13 (19-04-13, 11:50 PM)Young rider link Wrote: I'm gonna buy the extraction tool tomorrow see if that moves it. Don't wanna cause more damage. In that case I would really recommend you get a set like this; http://www.amazon.co.uk/Laser-4393-Impact-Stud-Extractor/dp/B001DYRDU2/ref=sr_1_1?ie=UTF8&qid=1366416058&sr=8-1&keywords=laser+stud+extractor I bought a set of fixed size stud extractors that are supposed to tighten on to the stud as you turn them, but they were useless. The above set from Amazon is what I bought ![]() You want something that has minimum range below 6mm. The stud is 6mm and the 3/8" one starts at 6mm so its hard for it get a very good tight grip but I found it very hard to find the 1/4" one on its own. On top of this, I used a impact driver to loosen the stud before using a socket wrench to finally get the studs out. I got my Impact Driver from Halfords; http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_530655_langId_-1_categoryId_165572 Re: HELP NEEDED - Young rider - 20-04-13 All fixed with a help of a stud extractor and a heat. Manage to enjoy some of the sun today
Re: HELP NEEDED - Chris - 20-04-13 Glad you got it sorted without having to take the engine/head out. 8) Chris Re: HELP NEEDED - Young rider - 20-04-13 (20-04-13, 11:04 PM)Chris link Wrote: Glad you got it sorted without having to take the engine/head out. 8) yes same here as that would off been a big job to doo! also thanks to dead eye for your help and advice
Re: HELP NEEDED - Dead Eye - 21-04-13 You're more than welcome Glad to hear you had good results - my studs were so bad that 7 snapped of which 2 of those snapped again but flush with the head.The engine out isn't the hardest thing in the world, but it does take time. Got mine out in a day and reassembled in one more day - took me a month or so to do the gearbox swap on my cage :| Re: HELP NEEDED - packie - 21-04-13 (19-04-13, 11:43 PM)richfzs link Wrote: Not wd40, as it's not penetrating fluid.http://wd40.com/uses-tips/ WD-40 loosens and penetrates rusted or stuck bolts and plumbing joints Re: HELP NEEDED - richfzs - 21-04-13 well packie, I grant it's better than water. But if it was actually any fuckign good as a penetrating oil, I guess they wouldn't have to make a real penetrating oil, huh? http://www.wd40specialist.com/products/penetrating-oil/ Re: HELP NEEDED - Jimmygixxer - 21-04-13 WD40 sucks balls. Last resort stuff Re: HELP NEEDED - simonm - 22-04-13 (21-04-13, 03:11 PM)Jimmygixxer link Wrote: WD40 sucks balls. I would have thought that would make it good ? :evil
