do you think my oxford grips have packed up? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: do you think my oxford grips have packed up? (/showthread.php?tid=62931) |
do you think my oxford grips have packed up? - devilsyam - 16-04-13 my oxford grips been working fine but this morning turned them on and the first heat light just flashes wont go up in heat setting either do you think the controllers is kaput?? Re: do you think my oxford grips have packed up? - ghostbiker - 16-04-13 Try increased revs a little then turn them on. Mine used to flash if it decided it wanted more current before turning on. Re: do you think my oxford grips have packed up? - smegfish1 - 16-04-13 I had the same sort of thing, turned out to be the battery. Re: do you think my oxford grips have packed up? - b1k3rdude - 16-04-13 If u have the digital controller version, those controllers are very picky about voltage, anything below 11-12v and they can cut out. Also said controllers have a habit of dying. Re: do you think my oxford grips have packed up? - AdieR - 17-04-13 Do you only get the problem at idle, or does it happen at higher revs too? I get the same with my Oxfords at idle (rpm too low for alternator to start charging), and goes back to normal once engine speed rises. Re: do you think my oxford grips have packed up? - keithfzs1000 - 17-04-13 you will probably find that the voltage of the battery is low Re: do you think my oxford grips have packed up? - devilsyam - 17-04-13 na no difference when running turn on goes right to 40% but wont go up or down grips get warm so suspect the controller now Re: do you think my oxford grips have packed up? - keithfzs1000 - 18-04-13 ahh tis now a different problem as the blue light deffo flashes when battery voltage is less than desired however if it goes up to 40 then sticks you are correct sir the controler is shall we was fooked :'( however search flea bay as they do come up as individual items without having to buy the whole kit and caboodle Re: do you think my oxford grips have packed up? - tomjimtom - 18-04-13 Mine did this, a quick email to oxford and sent the kit off for inspection (no receipt) and they said yup, switch is gone, here's a new one. Worth a try
