Head Bearing Adjustment - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Head Bearing Adjustment (/showthread.php?tid=62906) |
Head Bearing Adjustment - Timbo - 15-04-13 Hi All Has anyone here had experience of head bearing adjustment on a Gen1 Fazer. It's low mileage 12000 I have stripped and cleaned mine (and have done the swinging arm bearings as well) and purchased the Yamaha adjustment tool. My question is that having followed the setting procedure I feel that the steering is much looser than it was before. I have just had the bike MOT'd and ask specifically for their opinion on whether they were loose. The bike shop said the bearings were fine. I am satisfied that they are not so loose that there is any play in the bearing but they do not feel the same as they were before. I have ridden it since and I don't feel that I could apply the same amount of counter steering input as I did before without getting a surprise reaction from the bike. Is it the case that the head bearings were over tight from the factory? Has anyone else used the Yamaha C spanner for adjustment? The Haynes manual states that the torque wrench is used at 90° to the tool, the Yam manual states the same thing but illustrates the torque wrench in a normal position i.e 90° to the axis of the bearing. Do I just tweak them up a bit until they "feel right"? Comments please Thanks Tim Re: Head Bearing Adjustment - phil on a fazer - 16-04-13 i had the same with my Tenere. What i normally do with head bearings is tighten them so they are a tad too loose...you can feel the play by rocking the forks. this lets you known that nearly all the play is taken up. I then tighten them a bit more, check the play has gone and bobs your uncle. But as you say they do feel loose, but i think this is down to freshley greased bearings :b Re: Head Bearing Adjustment - tommyteeman - 16-04-13 there does seem to be quite a big range where the bearings are fine, mine i like to do them tight, so the bars wont flop to one side when the front wheel is off the ground (on the stand). As long as theres no back/foward movement front the front end they'll pass themot but I always go for a tighter set up. If you try to set them without the front wheel in, the movement needs to be fairly stiff cause when the wheel goes back in adds a lot more weight. Used to set my supermotos so you could feel the notchiness of tight bearings then slacken by a 1/4 of a turn, spot on, cured a lot of bar flapping. Re: Head Bearing Adjustment - Tmation - 16-04-13 Did you fit taper roller bearings or the standard ball? I don't know what is says in the manual but for the last 40 odd years I have always seated the bearings by tightening up until the steering no longer moves or is tight then back off 1/4 of a turn (or a little more) until the steering moves easily with no notchiness or rocking movement. Obviously check the manual as things change over the years. |
