Does exhaust leakage matter? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Does exhaust leakage matter? (/showthread.php?tid=62887) |
Does exhaust leakage matter? - Jimmygixxer - 14-04-13 After reassembling my micron exhaust, i noticed where the link pipe meets the headers there is a small amount of blowout. Alot of people seem to try and get an airtight seal in these areas. Does it make much difference to anything? My bike will backfire a little bit off the throttle from highish revs, is this a possible factor or not? Re: Does exhaust leakage matter? - darrsi - 14-04-13 Ideally it should be a good seal but i don't think it's a major. My bike used to pop on deceleration, but it went away when i got the carbs balanced. Re: Does exhaust leakage matter? - red98 - 14-04-13 could fail mot if tester spots it....if origanal steel pipes get them welded before it gets any worse
Re: Does exhaust leakage matter? - keno - 14-04-13 Had that problem with my fazer a few years ago, i just bought some heat resistant sealant smothered it on then joined together and left to cure for 2 days,problem solved. Mine was really bad so had no choice. Re: Does exhaust leakage matter? - Young rider - 14-04-13 mine does that too kinda like the popping noise. never bothers me with the leaking bit.[size=78%] [/size] Re: Does exhaust leakage matter? - Dead Eye - 14-04-13 Isn't the popping noise due to a bit of fuel vapour that isn't burnt off when chopping the throttle at high revs combusting in the exhaust? Can't see it being anything to do with a small exhaust leak... Re: Does exhaust leakage matter? - bwizz - 14-04-13 My old fazer had a slight leak on the front pipes , It used to pop and bang on overun sounded ok I thought at the time Re: Does exhaust leakage matter? - Jimmygixxer - 14-04-13 (14-04-13, 06:43 PM)Dead Eye link Wrote: Isn't the popping noise due to a bit of fuel vapour that isn't burnt off when chopping the throttle at high revs combusting in the exhaust? Can't see it being anything to do with a small exhaust leak... Thats what i thought, but seen a few people online saying thats what was causing their problem. Re: Does exhaust leakage matter? - bandit - 14-04-13 If you want to sort it this is the stuff, http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173139_langId_-1_categoryId_255217
Re: Does exhaust leakage matter? - Jimmygixxer - 14-04-13 (14-04-13, 09:05 PM)bandit link Wrote: If you want to sort it this is the stuff,thanks Re: Does exhaust leakage matter? - Easy Rider 13 - 14-04-13 i have a micron Exhaust and also have a small amount of leakage.... this is usually normal and is the condensation from when you first start up the bike. ive never failed a MOT or had any problems with it.... ALSO, the popping noise is awesome, especially if you're going under a bridge or through a tunnel! :lol Re: Does exhaust leakage matter? - darrsi - 14-04-13 This fella explains the 'popping' quite well: http://forum.motorcycle-usa.com/default.aspx?f=18&m=398516 Re: Does exhaust leakage matter? - Dead Eye - 15-04-13 Nice find darrsi, was a good read
Re: Does exhaust leakage matter? - keno - 15-04-13 My fazer 600 & zrx 1200 both pop and fart on the overrun. Zrx is the loudest but sounds great,its all part of the aftermarket replacements. If it bothers you get jetted. |
