Rear Axle bolt - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear Axle bolt (/showthread.php?tid=62873) |
Rear Axle bolt - Notch000 - 13-04-13 Can anyone tell me what size the rear axle bolts are? My socket set only goes to 20mm which is too small so need to get a new socket head to tension chain Re: Rear Axle bolt - limax2 - 13-04-13 Nut is 27mm across flats and the spindle head is 24. Re: Rear Axle bolt - Notch000 - 13-04-13 any idea what that is in socket, spanner size Re: Rear Axle bolt - limax2 - 13-04-13 A socket or spanner will be marked "27mm" and "24mm". I wouldn't use an open ended spanner but a ring spanner would be o.k. except you can't tighten it to the correct toque with one. You should use a socket and torque the nut up to 117Nm. In the absence of a torque wrench that is best described as jolly tight. |
