exup bolts - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: exup bolts (/showthread.php?tid=62772) |
exup bolts - kylron - 07-04-13 Just wanted to thank ghost biker again for the stainless exup bolts he recently sent out,finally got round to fitting them,had to take the exhaust off and heat one and drill another to get the old bolts out. Have ordered some stainless nuts for the header pipes so next time it will hopefully go a lot smoother. exup bolts - Exupnut - 08-04-13 Amen brother kylron
Re: exup bolts - red98 - 08-04-13 morning exupnut,was that the fittings on the exhaust you had to heat/bore or on the exup valve ? still not done mine and i have a slightly lumpy idle :rolleyes Re: exup bolts - kylron - 08-04-13 It was the three bolts holding the ex up plate on the exhaust on mine,the cover bolts came off with lusol but the other three wouldn't move until I took the exhaust off the bike and used the blow torch on them. Re: exup bolts - red98 - 08-04-13 (08-04-13, 09:27 AM)red98 link Wrote: morning kylron,was that the fittings on the exhaust you had to heat/bore or on the exup valve ? still not done mine and i have a slightly lumpy idle :rolleyes looks like it will take a bit longer than i expected :rolleyes still got to be done and then i`ll make it part of my servicing routine
Re: exup bolts - Exupnut - 08-04-13 None of mine stuck. I jus said get the fuck out, i got GHOSTBIKERS bolts comin in there an they shit themselves. Re: exup bolts - kylron - 08-04-13 Hi red98,I think the previous owner had been trying to do mine as the Allen bolts were all rounded off which made it harder.my advice would be to use a load of penetrating fluid like plus gas or lusol for a few days before you try to remove them. |
