FZ6 Forks - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZ6 / FZ6 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=77) +--- Thread: FZ6 Forks (/showthread.php?tid=62761) |
FZ6 Forks - Mooks - 07-04-13 Hi all, Anyone know if it's possible to weld on to the fork lowers without damaging them? It would be a very small piece. Cheers Re: FZ6 Forks - AdieR - 08-04-13 Can't see it being an easy job; them things will be aluminium which will twist and warp quite easily (once it does, it won't come back straight either. Cast ali will be even worse (it requires pre-heating before welding) and isn't always successful either. If you're intending welding with the forks fitted, make sure you isolate any sensitive electronics (ECU / ABS / immobiliser etc) - welding current can potentially damage these. I would seek the advice of a *good* welding / fabrication shop (one that can handle aluminium welding, not all can) and see what they say. Re: FZ6 Forks - Mooks - 08-04-13 Thanks for the reply. Its not looking like much of an option. I'll have to have a think about an alternative. Re: FZ6 Forks - Grahamm - 09-04-13 What do you want to weld onto them? Could you do it with some sort of clip instead? Re: FZ6 Forks - Mooks - 09-04-13 I was Looking at doing the R6 fork swap. Trouble is, mines got ABS, and the R6 doesn't have it. I haven't got the R6 forks to look at yet, but I'm guessing they wont have the little tab on them, that locates/holds the front sensor housing in place. Looking at the FZ6 forks, as far as I can tell, it would be the only thing hindering the swap. Just trying to get an idea of whats involved before forking out the cash on parts. Re: FZ6 Forks - AdieR - 10-04-13 Maybe easier to get a bracket made up / fabricated for the sensor, and fit it using the existing screw / bolt locations? (Haven't seen the R6 forks in detail). |
