Changing spark plugs on 04 FZS1000 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Changing spark plugs on 04 FZS1000 (/showthread.php?tid=62688) |
Changing spark plugs on 04 FZS1000 - Luath - 03-04-13 Hi all, I want to change the spark plugs on my Gen1 FZS1000. Can anyone tell me the best way to go about this. Also which would be the best replacements. Thanks...... Re: Changing spark plugs on 04 FZS1000 - sadlonelygit - 03-04-13 should we tell him.............or wait for the 'what the foc is that thing on top of the motor?' search AIS removal firstly .....and welcome Re: Changing spark plugs on 04 FZS1000 - phil on a fazer - 03-04-13 (03-04-13, 11:55 AM)sadlonelygit link Wrote: should we tell him.............or wait for the 'what the foc is that thing on top of the motor?' oh yeah...removed mine so long ago i had forgot about it...and the joys of changing plugs with it in situ. I use iridium plugs, seem pretty good. If You use the yamaha spark plug tool make sure it has the rubber insert iniside it (mine didnt!). it grips the plug.....and with out it....it....well doesnt :rolleyes Re: Changing spark plugs on 04 FZS1000 - Kosmic Kartman - 03-04-13 Don't know what all the fuss is about. Never had a problem even with the AIS in place. It's a bit easier once the AIS is removed... But using the spark plug socket in the Fazer tool bag is always the best option. Re: Changing spark plugs on 04 FZS1000 - AyJay - 03-04-13 Buy a torque wrench! After that, it's a 15 minute job. You should try changing the plugs on my ZZR if you think a Fazer might be difficult. Honestly, it's a doddle. I do wonder just how often they need changing though. My iridiums were fine after 40,000 miles and the only reason I changed them was because I'd already bought new ones and I thought 'may as well' Re: Changing spark plugs on 04 FZS1000 - PaulSmith - 04-04-13 I used to use Iridium, and thought they were the canine dangly bits. Couldn't afford them one year and went back to standard plugs. And thought they were the canine dangly bits too. It took a while, but I finally learnt that it was the fact that the plugs were new, not what they were made of, that made the difference. Re: Changing spark plugs on 04 FZS1000 - ghostbiker - 04-04-13 Iridium plugs just last longer, so if your changing them at specs interval then not worth the extra dosh. but if your likely to let them run longer than that they do stay fresh for longer. i tend to use them because i had an old ZX10 that ran rough as bugger and improved a huge amount with iridium plugs, swapped back to fresh std plugs and ran rough again. now it clearly had an underlying problem but back then plugs were about as far as i ever went lol and if they made an improvement then they had to be better than normal ngk ones. now i know better but i do still try when able to stick with the iridium plugs. even though i know they realy are not a wonder plug just a good plug. Re: Changing spark plugs on 04 FZS1000 - tomlinscote - 04-04-13 +1 for using the yamaha tool for this job, then its not a problem even with the AIS still in place. Tommo Re: Changing spark plugs on 04 FZS1000 - fazerblue - 05-04-13 to be honest I don't know what a ais is but I just used a normal plug socket and changed them without any difficulty Re: Changing spark plugs on 04 FZS1000 - tomlinscote - 05-04-13 AIS air induction system or is it air injection system anyway its a way to avoid emmsions problems in certain countries, it nmakes little if no difference to performance and can be remnoved with a suitable kit, like the one Justy used to supply, it makes servicing easier if it is removed Re: Changing spark plugs on 04 FZS1000 - Luath - 07-04-13 Thanks folks for your help and advice, I have the yamaha plug tool so I'll have a go with the AIS in place. Great site....
Re: Changing spark plugs on 04 FZS1000 - fazerphil - 09-04-13 i ve just done mine because i didnt know how long the old uns had been in. new ngk iridiums gapped to 0.75 mm and carbs balanced. i,d swear by these plugs and if you look on ebay you can find um cheap. |
