Horrible final drive clunking - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Horrible final drive clunking (/showthread.php?tid=62685) |
Horrible final drive clunking - Mr Juju - 03-04-13 Hi All, new to Fazer ownership (3 weeks) but haven't smiled soooo much in ages. I am getting a horrible vibration / clunking through the pegs most noticeable at about 4,000 revs - 40 mph but seems to be there whenever I throttle on. Don't notice it when I hit the powerband Any ideas , I have had a quick look around the forum but can't seem to find anything. Cheers! Pete Re: Horrible final drive clunking - Gnasher - 03-04-13 Check your drive chain adjustment and the front sprocket! Re: Horrible final drive clunking - darrsi - 03-04-13 Look at the actual chain as well for links that don't appear to be as horizontal as the others, you may have seized/rusted links. They tend to sit at a slight angle, and will make the chain a bit lumpy which will be felt through the left foot peg. Maybe worth laying off the power band until you sort this problem out! Re: Horrible final drive clunking - eddie1310 - 03-04-13 I had the same problem last week and it turned out to be a tight spot in the chain, Im fitting a new chain and cogs tomorrow so ill tell you how it goes Re: Horrible final drive clunking - Dead Eye - 03-04-13 Had this when I first bought my red bike, turned out it needed new chain and sprockets... happened at exactly the same speed / revs that you mentioned as well Re: Horrible final drive clunking - darrsi - 03-04-13 (03-04-13, 12:31 PM)eddie1310 link Wrote: I had the same problem last week and it turned out to be a tight spot in the chain, Im fitting a new chain and cogs tomorrow so ill tell you how it goes I suddenly had 2 links seize up on my chain, even though i cleaned and lubed it regularly, i think the bad weather and salt just takes it's toll over time. Had a nice new chain and sprockets fitted yesterday, now it feels sweeeeetÂ
Re: Horrible final drive clunking - Mr Juju - 03-04-13 Excellent! Thank you all for your helpful and prompt replies. I will give the chain a thorough examination and see what I can find ![]() |
