Fazer 1000 gen 1.. FORK OIL...talk to me! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fazer 1000 gen 1.. FORK OIL...talk to me! (/showthread.php?tid=62639) |
Fazer 1000 gen 1.. FORK OIL...talk to me! - jonjenk - 31-03-13 I have a mint 2001 FZS1000 with only 11k on the clock. As it is 13 year old I've decided to change the fork oil. I emptied the tubes and some smelly grey stuff came out so i'm glad I decided to change it. I need to re-fill the tubes... Can anyone give me any advice on the weight of oil and the quantity/air gap to improve the forks without changing the springs? If I were to replace the springs what would be the best/most cost effective way of improving the forks? I have just fitted a brand new original shock to the bike. Thanks, JOHN Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - kebab19 - 31-03-13 2.5w oil helps suppress the harshness a good bit. I replaced my springs with those from an XJR1300 to cope with the extra weight. Other options are rebuilding them with aftermarket cartridges such as those made by k-tech or fitting other forks. Mike (Falcon) went with USD R1 forks & yokes which are great. http://fazer1000.yuku.com/topic/3408#.UVhxSTeAZcM I went with R6 2003 RWU forks which fit the standard Fazer yokes. http://fazer1000.yuku.com/reply/23677/Re-R6-forks-nonUSD-for-Gen1#.UVhxZjeAZcM Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - sadlonelygit - 31-03-13 i firstly went with a respring and re-oil and now have an R1 front end. firstly, what weight are you, that will determine if you need a respring. secondly, as has been said a lighter oil gives a smoother damping action, but you need to experiment with air gaps as the rebound is a lot softer. Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - jonjenk - 31-03-13 I'm around the 16 stone mark (but the missus would like me to be 13) and although I don't often carry a passenger, I do carry luggage on trips. Other posts on here talk about using 10w oils and specify air gaps... All I'd like is to get a good feeling, well damped and sprung front end using as much of the original bike as possible. Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - sadlonelygit - 31-03-13 0.95 or 1.0 kg/mm linear spring 5 or 2.5wt oil 140mm air gap or 440cc per leg. don't forget to bleed the suspension Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - jonjenk - 31-03-13 (31-03-13, 08:50 PM)sadlonelygit link Wrote: 0.95 or 1.0 kg/mm linear spring Bleed suspension??? enlighten me please Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - Exupnut - 31-03-13 Its all bollocks if u have a good mechanic Sent from my iPhone using Tapatalk 2 Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - jonjenk - 31-03-13 (31-03-13, 10:14 PM)Exupnut link Wrote: Its all bollocks if u have a good mechanic Very helpful. Thanks. Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - Exupnut - 01-04-13 Then try something like this. http://www.ovalmotorcyclecentre.co.uk/web/index.php Dont know where u r but if u could find somethin similar its worth it. Sent from my iPhone using Tapatalk 2 Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - Exupnut - 01-04-13 Thanks. Lol Sent from my iPhone using Tapatalk 2 Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - sadlonelygit - 01-04-13 (31-03-13, 09:03 PM)jonjenk link Wrote: Bleed suspension??? enlighten me please download a manual, far easier than me explaining it to you. Re: Fazer 1000 gen 1.. FORK OIL...talk to me! - Tmation - 01-04-13 And you can download it from here. http://foc-u.co.uk/index.php?action=downloads;cat=4 |
