Brake disc skimming - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Brake disc skimming (/showthread.php?tid=62624) |
Brake disc skimming - Stedman8 - 30-03-13 Just wondering if its possible to get the discs skimmed and if so how much would it cost approx, and what the minimum thickness for a disc is ,cheers Steve Re: Brake disc skimming - darrsi - 30-03-13 Normal wear limit is 4.5mm, they're not thick enough to skim. Re: Brake disc skimming - packie - 30-03-13 ....plus they'd cost a bit to get done. Every engineering works will have different rates, so you will need to shop around. Re: Brake disc skimming - darrsi - 30-03-13 Why would you want it skimmed, what is the problem? Re: Brake disc skimming - Dead Eye - 30-03-13 Well with a question like this I assume the discs have become warped and the open was hoping they could be skimmed to restore them
Re: Brake disc skimming - darrsi - 30-03-13 (30-03-13, 11:40 PM)Dead Eye link Wrote: Well with a question like this I assume the discs have become warped and the open was hoping they could be skimmed to restore them People presume their discs are warped, but it's not always the case. This is one subject i have a lot of experience at, believe me! Re: Brake disc skimming - Stedman8 - 31-03-13 What it is, I was thinking of buying some second hand discs and just thought that maybe if there was a little damage on them or they were warped slightly if it would be possible to get them cleaned up or sorted somehow, I haven't bought them yet and there's probably nothing wrong with them at all - it just got me thinking about whether it was possible to take a mil off a disc,cheers for the replies anyway so I take it that its probably too expensive,and a waste of time and its probably better to wait for a lottery win and buy new ones if they get damaged :lol Re: Brake disc skimming - darrsi - 31-03-13 Believe it or not new discs are only about 1mm to 1.5mm extra than the wear limit. Re: Brake disc skimming - Stedman8 - 31-03-13 Has anyone any idea on how long a new disc would last before it needed replacing - I know they'll be variations like how hard you are on your brakes, conditions they are used in ,summer or winter use etc but what parameters are we talking given normal road riding in decent conditions and say 10,000 miles a year or is it the case that when it needs changing it needs changing :lol Re: Brake disc skimming - darrsi - 31-03-13 Fronts last way longer than rear because they're "floating". The outer disc that stops you gets hot, but doesn't transfer the heat to the inner part, whereas the the rear is one plate and receives all the braking heat, hence the reason people have so much grief undoing the bolts. All depends on the grade of pads used really. Organic pads are soft and will wear out quicker and create more dust, sintered are harder and will bite more but are more abrasive. I just wore out an EBC Pro-Lite rear disc with sintered Galfer pads in 11 months, but i had a front brake issue so compensated by over using the rear brake. Re: Brake disc skimming - Stedman8 - 31-03-13 Cheers for that darrsi- great explanation made it clearer about what floating meant and the difference between the pads used - all these bits of info come in really handy , especially when you bugger around with things as much as I do
Re: Brake disc skimming - darrsi - 31-03-13 Not bad considering i'm mullered texting from the pub on an unusual weekend off work :b Re: Brake disc skimming - packie - 31-03-13 (31-03-13, 12:52 AM)Stedman8 link Wrote: Has anyone any idea on how long a new disc would last before it needed replacing - I know they'll be variations like how hard you are on your brakes, conditions they are used in ,summer or winter use etc but what parameters are we talking given normal road riding in decent conditions and say 10,000 miles a year or is it the case that when it needs changing it needs changing :lol Well if its a Cop that I know, his discs would last about 100,000 miles. This guy is an excellent pilot and uses about 95% engine braking. I could be up behind him for 2-3 hours of hard riding, and you'd only see his brake light come on only a handful of times. Re: Brake disc skimming - Lumpy - 02-04-13 (31-03-13, 01:07 AM)darrsi link Wrote: Fronts last way longer than rear because they're "floating".please would you clarifiy what you mean on both of these points. The temptation was to dispute both but I'd best find out what you mean before I discredit it. See, I'm being diplomatic My rear caliper is a 2 piston affair, opposed, and I think the standard is too, so the fact the disc is not floating shouldn't make any difference because the caliper is. |
