Double D-Ring Helmets - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Double D-Ring Helmets (/showthread.php?tid=62607) |
Double D-Ring Helmets - Lazarus - 29-03-13 Guys, Got a full face HJC helmet with the double-d ring fastener. its not my favourite mode of fastening due to FFS (Fat Finger Syndrome) and prefer the ratchet style of the Caberg helmet. However - the Double D ring has a red pull tab on one of the double-D rings to help to loosen when taking off. Problem is - mine was pulled off Can someone confirm WHICH ring the pull tab is fastened to - im going to replace with a velcro zip tie. Re: Double D-Ring Helmets - Tiberius Onklevaart - 29-03-13 Just stick a finger under the strap and flick the ring That always helps my problematic helmet Re: Double D-Ring Helmets - stevierst - 29-03-13 (29-03-13, 01:24 PM)Tiberius Onklevaart link Wrote: Just stick a finger under the strap and flick the ring Oh I can't stop childishly chuckling )Sent from my HTC One X using Tapatalk 2 Re: Double D-Ring Helmets - Lazarus - 29-03-13 (29-03-13, 03:13 PM)stevierst link Wrote: [quote author=Tiberius Onklevaart link=topic=6983.msg66118#msg66118 date=1364559841] Oh I can't stop childishly chuckling ) Sent from my HTC One X using Tapatalk 2 [/quote] I must be as bad as you Re: Double D-Ring Helmets - J_Dub - 29-03-13 The bottom ring, the one against the chin strap. Flick your ring if you really want to but I don't see how that gets your lid off :eek Re: Double D-Ring Helmets - purplebear7 - 29-03-13 Check this out .. you can turn the Double-D system into a Happy Snappy :o) No damage or mods to Helmet, No Tools Req to it, No Hardly Dangerous name markings 8) Job Done in one minute. Works really well for the Funny Fat Finger Clan .. I'm member too :\ Echo Quick Release: How to add a Quick Connect to Your Helmet StrapOnce adjusted and set this idea works OK for 'normal' speeds .. but you might want to pull you chin strap slightly tighter for 140 mph plus? Just info: Stay Safe Trev
Re: Double D-Ring Helmets - Jamieg285 - 02-04-13 (29-03-13, 01:02 PM)Lazarus link Wrote: Can someone confirm WHICH ring the pull tab is fastened to - im going to replace with a velcro zip tie. If you 'do up' the helmet when not wearing it, you will only see one ring (the other is underneath the looped back strap). It's the visible one that has the tab. |
