Exhaust Gas Leak - Solution ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Exhaust Gas Leak - Solution ? (/showthread.php?tid=62505) |
Exhaust Gas Leak - Solution ? - Enceladus - 22-03-13 hi all just remembered that my bike is due an mot next month :eek i think there is a small gas leak on the exhaust where the end can meets the pipework. i assume that this would be a fail. is there anything i can use to stop this that wont look hideous ? Re: Exhaust Gas Leak - Solution ? - reillypadraig - 22-03-13 I used silicone, clear stuf but after a couple of miles and a couple of bad rough roads later it was loose again and had to scrap it of, quick fix thou, I found some firegum, like gun gum but it works as a lube at first to ease exhaust pipework onto each other then forms a seal with that lube, have yet to get the funds for it, event though u think its only a tennor. Comes in a tube rather than the gun gum tub Re: Exhaust Gas Leak - Solution ? - bandit - 22-03-13 This is the stuff you need put a nice thick bead of it around the inside of the endcan & slide on. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173139_langId_-1_categoryId_255217 Re: Exhaust Gas Leak - Solution ? - Ben600 - 22-03-13 the best quick fix I came up with for a blowing silencer / link pipe joint was to cut a coke can, roll it up and use it as a gasket between silencer / link pipe. Works well, looks ok (can't see it) and is cheap and easy! |
