Mystery wire on the brink of failure. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Mystery wire on the brink of failure. (/showthread.php?tid=62489) |
Mystery wire on the brink of failure. - binarystarr - 21-03-13 Hi all I've just discovered a wire on the brink of failure but i can't figure out what it controls. There are 2 wires below the reservoir on the right, one is earth and one is live (brown). Its the brown one thats frayed and close to failure. Have a look at the attachment. Anyone know what this is? Something to do with the lights? Will be repairing tomorrow but though it would try and figure out what it's purpose is! Re: Mystery wire on the brink of failure. - Fazerider - 21-03-13 It looks like the wiring to the brake light switch. Had the same problem on my 600. Re: Mystery wire on the brink of failure. - sadlonelygit - 21-03-13 that looks serious......fire risk, especially right under the brake master cylinder and all that flammable dot4. i'd get the AA out to make safe other wise you might get a short, go puff and possibly maim a kitten or OAP. it's your brake light btw!! and sort those scabby bars out FFS!!!!! Re: Mystery wire on the brink of failure. - binarystarr - 21-03-13 Wow, thanks for the quick response guys - i'll rewire tomorrow. The bars are a bit scabby yes. But they suit the rest of the bike! Re: Mystery wire on the brink of failure. - locksmith - 23-03-13 and the bead on the window doesn't look properly seated. It may be letting water in. :lol Re: Mystery wire on the brink of failure. - mcsuffolk - 23-03-13 Hi.... Definitely looks like brake light switch wiring..... Could check it with a multimeter if you had one.... Worth sorting out before blows a fuse or worse someone drives into the back of you when they don't realise you are braking.... |
