Dog bones - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Dog bones (/showthread.php?tid=62410) |
Dog bones - JoeRock - 16-03-13 Would adjustable dog bones for the FZS 600 fit the FZS 1000? There's a set being sold on here that I'd not mind picking up, if they actually worked to raise the tail on my 1000! Re: Dog bones - Minty - 16-03-13 I raised both my 600 and 1000 by an inch, design for both was identical from what I can remember. Here's the measurements I obtained for the 1000 as I was going to make some, ended up getting some seconds in the end for a good price. It's not exactlty linear, and a few thousandths error shouldn't hurt. There's that much slop in the bolts size to hole size already. it doesn't require much precision. Here's some figures based on several postings of measurements made to raise and lower FZ1's. The centre to centre distance between the bolt holes and the resulting change in height. 137mm = 22.5mm 138mm = 17.4mm 139mm = 12.6mm 140mm = 8.1mm 141mm = 3.8mm 142mm = -0.2mm 143mm = -3.9mm 144mm = -7.3mm 145mm = -10.5 146mm = -13.5 147mm = -16.1 148mm = -18.5 149mm = -20.6 150mm = -22.5 151mm = -24.1 152mm = -25.4 |
