Power commander - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Power commander (/showthread.php?tid=62407) |
Power commander - stevierst - 16-03-13 I'm looking into buying a power commander for my 2010 fz1. Seen a few on evilbay for the R1, and wondering will it fit my bike?? Been on the PC website, and it's not too helpful in this area. Also seen a Two brothers juicebox, would this be an alternative? I'm a nuts and bolts kind of guy, and this electronics thing is wizadry to me!!! Re: Power commander - slimwilly - 16-03-13 i would buy one that says its correct for your bike,simple are you after the newer PCV or older PC3? Re: Power commander - stevierst - 16-03-13 As far as I know, they stopped making the PC 3 before the 10 plate came out, so they don't market for it. Only the PC 5 is advertised. Doesn't mean it doesn't fit though, I just haven't tried it. Sent from my HTC One X using Tapatalk 2 Re: Power commander - Tmation - 16-03-13 If it is for a 2010 + R1 then the engine is completely different, crossplane crank 4 valve heads etc. Is it just the wiring loom and map that is different, I don't know? Phoning up one of the better Dyno shops should shed some light. Re: Power commander - DekF - 17-03-13 The PC3 you need is either : FZ1 06 onwards or R1 04 - 06 or PCV for FZ1. I have the PC3 & Ignition module but the PCV is the way to go. Re: Power commander - stevierst - 17-03-13 (17-03-13, 10:51 PM)DekF link Wrote: The PC3 you need is either : FZ1 06 onwards or R1 04 - 06 or PCV for FZ1.Thanks DekF, that's more like what I was after. Ill be trying to source one as the airbox mod, and trimmed flies will lean off the mixture too much on their own. Needs the PC to remap it. ![]() Sent from my HTC One X using Tapatalk 2 |
