After Market clocks - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: After Market clocks (/showthread.php?tid=62260) |
After Market clocks - IanBitmap - 06-03-13 Hi Folks, I was thinking of changing my clocks on my 98 fzs600 to an aftermarket set - has anyone had any experience/or issues doing this? It looks possible, though i wasn't sure if i needed to do some funky with the throttle position sensor (i think it runs via the clocks, though will need to study the wiring diagram - i may be wrong..) Any help appreciated, Thanks Ian, Glasgow Re: After Market clocks - unfazed - 06-03-13 TPS does not go to the clocks. it works directly with the ECU/Ignitor. Don't know anyone who changed the clocks on a Fazer Re: After Market clocks - stevierst - 06-03-13 I did it on my '98 R1 which worked out fairly well. I used a Koso RX10. Not cheap, but did the job well, and was 'fairly' easy to fit. Sent from my HTC One X using Tapatalk 2 Re: After Market clocks - IanBitmap - 06-03-13 Ah cool - cheers for the speedy response; good to know the TPS isn't impacted - that nugget of misinformation was something someone had mentioned but admittedly I hadn't looked into yet. Nice to know it was fine on the R1 too ![]() |
