12v socket and sat nav fitted but compact Air Horn Woes - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 12v socket and sat nav fitted but compact Air Horn Woes (/showthread.php?tid=62075) |
12v socket and sat nav fitted but compact Air Horn Woes - Fizzy Pies - 24-02-13 not much to say about it really, realised the compact twin tone airhorn I've bought will be a nightmare to fit as its not so compact . gonna wait till Alex fits his as he had bought the same one and seems a pro at fettling! cool storey bro? :lol Re: 12v socket and sat nav fitted - darrsi - 24-02-13 I stuck my air horn just back from where you've put that 12v socket, there's a bracket under there that i think i had to trim down a bit then bolted the horn to it. There's a side view picture here: http://foc-u.co.uk/index.php/topic,5660.0.html Re: 12v socket and sat nav fitted - simonm - 24-02-13 I bought one of those satnav cases. Are we fellow cheapskates ? Re: 12v socket and sat nav fitted - simonm - 24-02-13 I was planning on doing exactly the same 12v socket install. Now wondering if I should keep it under the seat and route the cable instead. The idea of zip ties near my steering isn't something I'm too fond of. Re: 12v socket and sat nav fitted but compact Air Horn Woes - darrsi - 25-02-13 Excuse the wires, i've got other stuff going on down there! :rolleyes So the open screw hole you can see is for the rear screw of the left infill fairing panel. The open end of the horn is facing down to avoid any water issues. Re: 12v socket and sat nav fitted but compact Air Horn Woes - darrsi - 25-02-13 It's mounted to an original bracket (the rusting bolt under the blue connectors), although i vaguely remember something being hacksawed off to make room? This was done years ago so i'd need too see another bike that hasn't been tampered with to see exactly what i've done? The infill tray sits as normal. Re: 12v socket and sat nav fitted but compact Air Horn Woes - darrsi - 26-02-13 I'll be totally honest, electrics are definitely not my thing, i just wire things as i go along as per instructions, and as my air horn was fitted years ago that drawing doesn't mean too much to me! But i'm sure some nice chap on here will point you in the right direction! Having electronic engineers at work is a kind of bonus for me too Have a look at this :thumbup : http://www.google.co.uk/imgres?imgurl=http://www.nathanielsalzman.com/img/8_29_08/HornWiringDiagram.gif&imgrefurl=http://www.nathanielsalzman.com/diy/diy-stebel-nautilus-air-horn/&h=725&w=597&sz=14&tbnid=XYqV2OLuZ-dMWM:&tbnh=90&tbnw=74&prev=/search%3Fq%3Dwiring%2Bdiagram%2Btwin%2Bairhorn%26tbm%3Disch%26tbo%3Du&zoom=1&q=wiring+diagram+twin+airhorn&usg=__ZBIy1BhTi4LOEL5W79Qfs-HfWL8=&docid=kCyehzldqNGeJM&hl=en&sa=X&ei=OJ8sUfOsJ_So0AXTnYGADQ&sqi=2&ved=0CFcQ9QEwBA&dur=3921 12v socket and sat nav fitted but compact Air Horn Woes - Exupnut - 26-02-13 Try this fizz it may help. http://www.bikerhiway.com/images/large/amanet/snpnp_01_LRG.jpg Sent from my iPhone using Tapatalk 2 Re: 12v socket and sat nav fitted but compact Air Horn Woes - Ebme Geek - 26-02-13 Yes your diagram would work, but go with Darrsi or Exupnut, which ever you find clearest, Darrsi's doesn't show the fuse but are otherwise they're the same. That way the horn will only work when the ignition is on.
Re: 12v socket and sat nav fitted but compact Air Horn Woes - Ebme Geek - 26-02-13 Looks spot on to me
Re: 12v socket and sat nav fitted but compact Air Horn Woes - alexanderfitu - 01-03-13 (27-02-13, 11:08 PM)Fizzy Pies link Wrote: going off my last diagram then, could the - on the horn go to the - on the battery? It could, but would be easier to wire the ground through the bolt that the horn will mount onto.
Re: 12v socket and sat nav fitted but compact Air Horn Woes - alexanderfitu - 01-03-13 Happy days!
Re: 12v socket and sat nav fitted but compact Air Horn Woes - darrsi - 01-03-13 (01-03-13, 10:22 PM)Fizzy Pies link Wrote: Too late I went - off the battery Told ya there was a bit i hacksawed off!! Re: 12v socket and sat nav fitted but compact Air Horn Woes - bozboz - 02-03-13 Well done fizzy! -that was a headache in the chat room the other night!
