Charging tails - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Charging tails (/showthread.php?tid=62043) |
Charging tails - simonm - 21-02-13 Curious..... I've purchased one of these: http://www.ebay.co.uk/itm/120982024691?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 I'm wondering if I wire up a plug to a battery charger if this will trickle charge using the socket as a power input rather than an output ? Or should I get something like the following: http://www.ebay.co.uk/itm/MOTORBIKE-BATTERY-CHARGER-CONNECTOR-LEAD-RING-TERMINALS-/310605589036?pt=UK_Motorcycle_Parts&hash=item4851892a2c I'm worried about water ingress in to the connector, but with my new heated grips, usb plugs and alarm I want to keep the battery topped up. Re: Charging tails - alexanderfitu - 21-02-13 It will work either way. No need to get another connector if you need to! Try and get a connector with a cap that snaps back, it will help with water ingress. like this: http://www.ebay.co.uk/itm/12v-Waterproof-Socket-Motorbike-Motorcycle-Cigarette-Lighter-Accessory-Adaptor-/260965260790?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc2bdddf6 |
