Correct Oil amount - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Correct Oil amount (/showthread.php?tid=61917) |
Correct Oil amount - Tilts - 11-02-13 Could some one please tell me the correct amount I need for a filter and oil change for my Gen1 Fazer 1000. Cheers Re: Correct Oil amount - Tmation - 11-02-13 Pick up the workshop manual from this site http://foc-u.co.uk/index.php?action=downloads;sa=view;down=11 Re: Correct Oil amount - Tilts - 11-02-13 Great stuff, thanks. Re: Correct Oil amount - kab - 11-02-13 Just changed mine today, it took just under 3Litre to get to the top of the sight glass. Re: Correct Oil amount - Tilts - 11-02-13 Thanks Kab, ill check out the service manual to..
Re: Correct Oil amount - slimwilly - 12-02-13 Make sure you recheck the oil level after running the bike for a few minutes. Billy Re: Correct Oil amount - Tilts - 12-02-13 Will do, do you need one of the removal tools as states on the manual for the filter, if so where can you pick em up? Re: Correct Oil amount - budgiemurray - 12-02-13 Your local Halfords or motor factors should have them. Either that or use one of those rubber band with the handle thingys.. Budgie Sent from my GT-I9100 using Tapatalk 2 Re: Correct Oil amount - Tilts - 12-02-13 Got on e of them in the shed, ill give that a go before splashing out.... Re: Correct Oil amount - ghostbiker - 12-02-13 The cup ones are much easyer to use than the band or chain types on the gen 1 think I payed 6 quid for mine from my local bike shop. Re: Correct Oil amount - jackojet - 12-02-13 If you buy a K&N oil filter they have a hex head built in that you can get a socket or ring spanner on to undo , but as ghost says the cup type oil filter remover a godsend on standard filters
Re: Correct Oil amount - Tilts - 12-02-13 don't suppose you know what size? 65/68mm? Re: Correct Oil amount - jackojet - 12-02-13 Tilts I'm pretty sure it's 65mm . The one I have is a genuine Yamaha one, cost around a tenner IRC. Re: Correct Oil amount - slimwilly - 12-02-13 Mine that i just took off came off with just finger grip,, arhhhhh,,, frightened of what happens if it came off when riding. |
