help needed footpeg probs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: help needed footpeg probs (/showthread.php?tid=61883) |
help needed footpeg probs - bigcol - 09-02-13 hi i need to put new front foot pegs on my 04 fazer 1000 but can see how the old ones come off can any one help if the have changed theres ?????????????? :'( Re: help needed footpeg probs - karlo - 09-02-13 Take the pin out where they swivel or just unbolt it from the back? Re: help needed footpeg probs - bigcol - 09-02-13 i can not see how the pin comes out looks like a pot rivet???????????? Re: help needed footpeg probs - purplebear7 - 09-02-13 Hi Bigcol, You'll need to drill the front peg pins with a drill bit about the same size (or very slightly larger) Drill just enough (next to nothing) to remove the lip that stops the pins dropping out .. then tap them out with a punch of some sort. Easy job, don't let it throw you. The front pins are then of no use .. so you replace them with a nice stainless bolts, washers and lock nuts The rear pegs already use bolts .. if I recall correctly. Polar Bear
Re: help needed footpeg probs - purplebear7 - 09-02-13 You can see the Bolt here. Take care that the Springs don't go for a walkabout! :'(
