Best Chain for FZS 600 2003? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Best Chain for FZS 600 2003? (/showthread.php?tid=61867) Pages:
Best Chain for FZS 600 2003? - nobleFZS - 08-02-13 Hi all, Looking for any advice on the best chain to buy? My chain has taken a beating over winter and will change it out in a month or so. Cheers, as ever! ![]() Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Will you be changing the sprokets too? Re: Best Chain for FZS 600 2003? - richfzs - 08-02-13 Please note, the only correct answer to that question is Yes, of course I will Don't ask how I know... Sent from my HTC Desire S using Tapatalk 2 Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 (08-02-13, 11:35 AM)richfzs link Wrote: Please note, the only correct answer to that question is:lol Thought i'd ask anyway :lol Would I be correct then that most people go for the OEM kit instead of the renthal/tsubaki kit? Re: Best Chain for FZS 600 2003? - nobleFZS - 08-02-13 Yup, sprocket going too ![]() Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Then from what I can tell from on here the OEM kit, although more expensive, is the one to go for. Re: Best Chain for FZS 600 2003? - darrsi - 08-02-13 DID X Ring Gold heavy duty chain kit all the way for me, i'm very pleased with it. After 10yrs of a shaft drive bike i really wasn't looking forward to constantly having to adjust a chain, but i've barely had to touch it. As long as it's looked after and lubed properly it will serve you very well with minimal fuss. Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Yes, a very good point darssi, maintenance is the best way to give it long life no matter what you put on it. Re: Best Chain for FZS 600 2003? - nobleFZS - 08-02-13 This is great. Thanks a million, lads! ![]() Re: Best Chain for FZS 600 2003? - packie - 08-02-13 I just bought a DID X-Ring from M&P Direct. Haven't fitted it yet, but had no problems with DID on my other bikes. Also, take note of Darrsi's advice. Lubing and a full clean every so often goes a long way. If you have the money and are lazy, buy a Scottoiler. I put one on my Bandit 1200 and got 30,000 miles out of the chain with little or no maintenace needed. Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 do you guys use a DID X ring chain with new oem sprockets? Re: Best Chain for FZS 600 2003? - darrsi - 08-02-13 (08-02-13, 02:11 PM)Chris link Wrote: do you guys use a DID X ring chain with new oem sprockets? No, they came as a kit with the chain, and they've been absolutely fine. Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Ok, I see them on Ebay. Was the OEM front sprocket different though, as in had a rubber part to stop chatter. Like a cush drive kind of thing? Or have a read someones post wrong in another thread... Re: Best Chain for FZS 600 2003? - darrsi - 08-02-13 Doesn't ring a bell at all? My chain was fitted by my mechanic while he also changed my tyre last time, and i had the upgraded sprocket nut changed over too. Good job as well, as it took him about 40 minutes to get my old sprocket nut off, 'cos it had welded itself on, which is better than flying off instead i s'pose! Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Fair enough =) will have a quick look see if I can find the bit I read, although I was on nightshift so might have got it wrong. haha. Anyway, glad it's not been a problem for you ![]() I'm going to have to check that sprocket nut thing in the next few days before I put my bike back together. Re: Best Chain for FZS 600 2003? - richfzs - 08-02-13 Yeah Chris, the oem front sprocket had a rubber (or hard plastic, I forget) thing on it, that is reckoned to have been there to quieten things down. Can't say I noticed much difference when I changed, although others have. Mine was so worn when it came off, it probably overwhelmed the rubber bit :lol Sent from my HTC Desire S using Tapatalk 2 Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Woop! Didn't think I was going crazy...er... haha. Fair enough, I guess in that case then the DID x ring kit would be a good alternative then as it's cheaper but an OEM kit wouldn't be a bad choice either. Anyone got any opinions on the renthal/tsubaki kit? Re: Best Chain for FZS 600 2003? - darrsi - 08-02-13 (08-02-13, 02:51 PM)Chris link Wrote: Woop! Didn't think I was going crazy...er... haha. Have no idea about that brnd, but the DID kit is proven, popular and well worth the money. If you go down that road go for the heavy duty gold one. Re: Best Chain for FZS 600 2003? - nobleFZS - 08-02-13 I am convinced, Heavy Duty Gold DID Kit it is. Completely agree on the cleaning/maintenance point made earlier. Believe me I have tried! Been through a large can of Wurth Dry Chain Lube since the beginning of Jan as I have been applying it every day and clean chain at the weekend wash. However, I ride every day. And where I live (Aberdeen) is corrosion heaven at the best of times, but with all the snow and resulting treatments of the road it has been a losing battle. Spots of rust appearing in various places and the chain is one of them despite my best efforts :'( [size=78%]. So, as it has never been changed under my ownership I though an overhaul for the spring would be worth it. [/size] Cheers again for all the help, invaluable. ![]() ![]() ![]() Re: Best Chain for FZS 600 2003? - Chris - 08-02-13 Go for it! Has your bike had the upgraded front sprocket retaining nut yet? if not would be a fine chance to get that done ![]() Yes, living next to the sea, although very nice, does have it's down sides. Living in shetland I am never more than 3 miles away from the sea at any time... needless to say things rust very quickly if not treated and cleaned regularly. |
