Speedo correction (16 tooth) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Speedo correction (16 tooth) (/showthread.php?tid=61762) |
Speedo correction (16 tooth) - slimwilly - 03-02-13 So a couple of months ago i put a 16 tooth front sprocket on my FZ1s so i took a satnav on the tank pad to check out the speed correction. I found the bike to be over reading as expected , the speedo read 44 to satnav 40 ,speedo 55 to satnav 50 and so on, so there is a 10% over read, easy to calculate when riding. I got the speedo to read 142 and the satnav recorded 128 max speed of trip.(on a closed airfield of course) :\ On my Hilux pickup the sat nav reads slightly less than the speedo for cross reference,50 on the speedo and 48 on the sat nav so that 4% is my safety factor on riding at speed limits. SO as written about the sprocket change making a 5.4% over read and the inbuilt 5% over read on the bike speedo i know where i am. And as for the 16 tooth mod well, i takes away the need to change down to over take ( in most cases anyway) and makes for a smoother ride. I have recorder 130 miles on the milo and the fuel is flashing ,so have to check what is left in the tank as i want 150 miles to the tank or if not then the 17tooth is going back on. Four of us are riding to Mugello end of May, going through Switzerland , my mates gsxr 750 needs to stop at 150 miles so should be ok. Re: Speedo correction (16 tooth) - chaz - 03-02-13 don't forget you your m.p.g. should show a 5.5% increase if you're still getting the same m.p.g. Re: Speedo correction (16 tooth) - slimwilly - 03-02-13 I am expecting it to do 5.5% less mpg, but the throttle control is all to shit,,i cannot turn it steady, it wants me to turn it fast all the way :evil Re: Speedo correction (16 tooth) - BBROWN1664 - 04-02-13 and when your tyres wear out it will reduce by 4% Re: Speedo correction (16 tooth) - Chalky - 04-02-13 http://www.healtech-electronics.com/ A Speedohealer will sort your speedo, doesn't take long to fit and works a treat. |
