Sat Nav Mounting for Zumo 660 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Sat Nav Mounting for Zumo 660 (/showthread.php?tid=61677) |
Sat Nav Mounting for Zumo 660 - Don71uk - 29-01-13 Hi, I had before a quest which was mounted on a ram mount by the clutch so before I mount the zumo has anyone got ideas as to the best place to fix the sat nav? Same place, in the centre, etc.. If you have any pictures with bike and gps please post, thanks. don. Re: Sat Nav Mounting for Zumo 660 - Tmation - 29-01-13 I Have Zumo 550 on mine, sorry no real close up photos. ![]() ![]()
Re: Sat Nav Mounting for Zumo 660 - Don71uk - 29-01-13 Thanks for the pictures, that is where I had mounted the quest, so the zumo might go in the same place. Don. Re: Sat Nav Mounting for Zumo 660 - Mick-H - 29-01-13 Tmation like the looks of the screen in the top photo, how'd you do that. I'd say that's about the best place to put one, be careful though that you don't block off the speedo with the satnav holder and remember the 660 is wider so once on you'll prob have to use it as the speedo as well. Re: Sat Nav Mounting for Zumo 660 - Ketty - 29-01-13 I have a 660 and couldn't decide where to mount it, not keen on the ram mount on the bars as I wanted it more in my line of sight and out the way a bit more. Ended up making a bracket mounted on the back of the clocks and then over the top of them, it obscures the tacho slightly but I don't find this an issue and without the sat nav mounted all is clear. I used some cardboard to make a template then cut and bent some aluminium I had lying around. ![]() ![]() not he best photos but you get the idea Re: Sat Nav Mounting for Zumo 660 - Tmation - 30-01-13 (29-01-13, 09:32 PM)Mick-H link Wrote: Tmation like the looks of the screen in the top photo, how'd you do that. Hi Mick, Screen is an MRA Vario with a Yamaha/MRA touring screen in place of the normal blade some more picture below (sorry for hijack :o ) ![]() Down and In ![]() Fully up and out (picture make screen look out of line but its not) ![]() Standard blade mounted upside down Re: Sat Nav Mounting for Zumo 660 - Mick-H - 30-01-13 I like that. :b Re: Sat Nav Mounting for Zumo 660 - Davidjw - 01-02-13 I have a Zumo 550 which I have mounted in the centre of the bars , I just like the balanced look it gives . Re: Sat Nav Mounting for Zumo 660 - Don71uk - 04-02-13 Got round to fitting the sat nav today, using the ram mount on the left handlebar, similar to Tmation's 550. Wired in so that I can remove the cradle and wire when the sat nav is not being used, only the ball mount is left on the bars. Thanks for all the pictures, Don. |
