My choke is stiff. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: My choke is stiff. (/showthread.php?tid=61664) |
My choke is stiff. - xlewisbdx - 28-01-13 Went to the bike this morning and put the choke and I had to put effort into to it. It's been fine up until today. Any suggestions? Re: My choke is stiff. - trudd - 28-01-13 How cold was it? Could be water in the cable that has frozen. Re: My choke is stiff. - alexanderfitu - 28-01-13 Probably a bit of water and other crud in the cables. Lubricate the handlebar mechanism with oil (not wd 40 etc!) and lube the lining of the cable sleeve
Re: My choke is stiff. - xlewisbdx - 28-01-13 What lube should I use? I was tempted to but some WD40 on it but I didn't because it was close the my inlet rubbers and WD40 doesn't agree with rubber (so I have been told) Re: My choke is stiff. - alexanderfitu - 28-01-13 3-in-1 oil works well Just use it sparingly or you will get lots of dirt etc sticking to where its applied. Its a good idea to apply wd-40 first to drive any water or grit away. Re: My choke is stiff. - alexanderfitu - 28-01-13 (28-01-13, 11:25 AM)trudd link Wrote: How cold was it? Could be water in the cable that has frozen. Great minds think alike
