Air filter - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Air filter (/showthread.php?tid=61565) Pages:
Air filter - ricksmith - 20-01-13 Hi Just replacing my air filter. Is it worth putting in a K&N or just an ordinary one, possibly a hi flo or something similar???? Thanks. Re: Air filter - darrsi - 20-01-13 100% K&N. For starters a few of us on here have noticed that Hi-Flo are ill fitting. Secondly, the K&N will be the last filter you ever buy for the bike so it's cost effective. Re: Air filter - Dead Eye - 20-01-13 +1 for K&N Re: Air filter - Andy FZS - 20-01-13 +2 Sent from my GT-I9300 using Tapatalk 2 Re: Air filter - Exupnut - 20-01-13 +3 Re: Air filter - DryRob - 20-01-13 +4 Re: Air filter - Skippernick - 20-01-13 Do you need to rejet at all? Re: Air filter - DryRob - 20-01-13 I've read on here a few times that the fzs runs rich as standard apparently so no need Re: Air filter - Dead Eye - 20-01-13 Had no need to re-jet on mine
Re: Air filter - darrsi - 20-01-13 No re-jetting but it will feel like the bike is taking a deep breath of fresh air after eating a packet of Tunes
Re: Air filter - unfazed - 20-01-13 Probably on of the most effective and simplest modification you can do to the fazer to improve it. No need to rejet as it runs rich as standard. The K&Nwill also improve the already good mid range a little, improve the mpg a little, run cleaner and give it a lovely throaty sound around the 7000rpm range. Re: Air filter - Dead Eye - 20-01-13 Got mine from fleaBay
Re: Air filter - Andy FZS - 20-01-13 +1ebay Sent from my GT-N8010 using Tapatalk 2 Re: Air filter - bwizz - 20-01-13 Now using KN but BBC hi flow filter that i used previously was equally good Re: Air filter - Fordy - 20-01-13 Try and by 1 now Re: Air filter - darrsi - 20-01-13 (20-01-13, 09:21 PM)bwizz link Wrote: Now using KN but BBC hi flow filter that i used previously was equally good If it was just as good, why did you have to buy another one? Re: Air filter - Dead Eye - 20-01-13 Possibly from a previous bike? Re: Air filter - bwizz - 22-01-13 Different bike! Re: Air filter - red98 - 23-01-13 +5 for k&n.......very well made and an excellent fit,no need to re-jet
Re: Air filter - reillypadraig - 23-01-13 i might be wrong on this so i stand to be corrected, i read somewhere that you dont need to adjust the carbs if you put on a non-standard exaust. and you dont need to adjust if u put in a k&n filter, but if you have a non-standard exaust already on, and then put in a k&n you will have to adjust to make it worth changing these parts (only if you change both) |
