Ignition Barrel - 5LV - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Ignition Barrel - 5LV (/showthread.php?tid=61416) |
Ignition Barrel - 5LV - camroc5 - 07-01-13 Hi all , I seem to have run into a problem. I have a 2004 FZS1000 (5LV) and the Ignition Barrel is broken. The key is loose , comes out when turned on , power flickers, bike cuts out and is unsafe. I ordered a replacement from a 2003-5LV and it does not fit. The orignial has 2 block connecters , one with 2 wires the other with 5 wires. The Replacement has one with 2 wires , but the other block only has 3 wires. I know that the 1C2 model is different and it has the 3 wire block connecter but does anyone know if there is two versions of the 5LV model. I was thinking I may have been sold the wrong part but they where sure its a 2003-5LV , then I thought that even though mine is reg'ed 2004 it could be a 2002 model. Can I use any other Ignition Barrel , or am i stuck finding a 2001-2002 model. or Does anyone know if I can still 'Wire' the two connectors block together?. Thanks, Camroc Re: Ignition Barrel - 5LV - The Male Whale - 08-01-13 I can't answer the question but suspect the one you have got is off the earlier models with switchable headlights and yours is permanent headlights??? Not sure if that helps..... Whale Re: Ignition Barrel - 5LV - camroc5 - 08-01-13 My bike is with the switchable headlights on the Right-Hand side. Mode 1 is front-side lights and rear lights , mode 2 is full front and rear. Maybe thats the extra two wires are for. Do you know when they changed the model to always on lights? Re: Ignition Barrel - 5LV - solorider - 08-01-13 the 2003 to 2005 had the same switch http://www.yamahamotorcyclespares.co.uk/spares/partImage.asp?GPN=Z%3AQ%5B%3D7%3A567555&uid=0 it is possible that the lock you bought was from a 2002 model registered in 2003 Re: Ignition Barrel - 5LV - sirgalahad3 - 08-01-13 The difference is indeed due to the hard wired lights on in the 03+ on bikes. If a bike/car is right on a change of spec like this it is sods law you will get the wrong part..giving the reg is no help as the bike could be a late registered early one.. You need to swop your new lock!! Re: Ignition Barrel - 5LV - ghostbiker - 08-01-13 As above, I had same problem early this year. It is as said pre light and post light switch. It's one of the few minor changes over the years. Re: Ignition Barrel - 5LV - devilsyam - 08-01-13 funny that i have a similar issue mines a 02 i got one of eblag but was for a non headlight version and was not as discribed so got me money back so after a cheap early version Re: Ignition Barrel - 5LV - camroc5 - 24-01-13 Ok then , I just messed up bad :'( I ordered the part from the above link , and its wrong. I didnt look at my VIN number correctly before i ordered. So..... just to be sure, can someone confirm. I have a Fazer 1000 with VIN number JYARN061......... It has the headlight swith on the right hand side. Does this mean its a 2001-2002 version of the bike? Does it matter thats its an EX-UP version , or are they all? I can order the part for the 'RN061' version , but I have been looking around the interwebs and Ebay , and some pictures for the 2001-02 model only show 1 connection box (with 4 wires). The broken part on my bike has 2 cables under the petrol tank , one has 2 wires that power the bike when connected , the other has 5 wires. I have not yet traced these , to see what each does. I need to wait till weekend to strip the wires. I am gonna try and hardwire a switch of some kind untill I can be sure Im getting the correct part. Re: Ignition Barrel - 5LV - sirgalahad3 - 25-01-13 Not sure about vin numbers but if your bike has a headlight switch its one of the earlier ones,probably pre 03. All Fazers are exup versions. Some ebay sites use a common pic of a part whatever it is. May I suggest you talk to a supplier and discuss with him exactly what you want as ebay is sure to go wrong under situations like this... May I also suggest you dont strip/bodge wires as that will also wrong! |
