Suspension upgrade - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Suspension upgrade (/showthread.php?tid=61414) |
Suspension upgrade - picker - 07-01-13 Hi to all new to this site so might f... up with this post. Has anybody upgraded their suspension with Maxton front or rear , or any recommendations or advice for me and my FZS1000 05 , just purchased , its my second one. I sold the first one 3 yrs ago and regretted it :evil , thanks Paul. Re: Suspension upgrade - devilsyam - 07-01-13 http://foc-u.co.uk/index.php/topic,151.0.html http://www.devilsyam.com/R6%20shaock.htm good start Re: Suspension upgrade - FuZzBoM - 07-01-13 I fitted a Hyperpro spring over Christmas and I am very happy with it so far. not only is it firmer than the original it seems to ride much better. I guess like anything it depends on your budget. I am tempted to get the fork springs to match the rear. http://www.ebay.co.uk/itm/Hyperpro-Progressive-Rear-Shock-Absorber-Spring-Yamaha-FZS-1000-Fazer-01-05-/200862536733?pt=UK_Motorcycle_Parts&hash=item2ec457141d Good luck and enjoy. Re: Suspension upgrade - picker - 14-01-13 Been on to both Maxton and a suspension supplier and KAIS in the North West [Atherton] both seemed to know there stuff , Maxton being the Most expensive at £330 for revalve , springs and set up for front with a possible 100 to replace cartridges as well total £430 for front, respring rear shock with stiffer spring to suit £100 or replace approx £590 with their own tailor made with ride height adjuster / preload.Total £1100 ish! KAIS quoted £291 for re-valve and set up for front no mention of wear in cartridges ? and £391 for a hyperpro rear shock again built to order but with no remote ride height adjuster/ preload told if you solo you dont really need to constantly adjust , makes sense. They also could remove the original spring which is too soft unless you weigh 8 stone wet through with a stiffer one for about the same £100 . Any thoughts ? I had an Ohlins on last FZS1000 looked mint but they are nearly a grand for the rear ! Re: Suspension upgrade - bigbluebear - 15-01-13 I've just fitted a Nitron NTR Sport, £360 fitted. Due to chronic weather conditions up here in I've not had the chance to fully test it properly yet. Re: Suspension upgrade - picker - 18-01-13 Best of Luck , hope it works out. Toured Scotland 2006 , real roads , stunning views great people , must go again. Skye was stunning. Re: Suspension upgrade - bigfootpete - 20-01-13 Nope but I have the R6 rear shock to sell if you want that instead I got it from DevilsYam, but found an Ohlins for slightly more so have the R6 shock to re-sell
