Diagnostic and CO codes FZ1s - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Diagnostic and CO codes FZ1s (/showthread.php?tid=61394) |
Diagnostic and CO codes FZ1s - wfbroddy - 06-01-13 **Like of total duffist, I found this info in the service manual Doh!, still don't understand the Co adjustment though **Folks, was wondering arounf the net and came across this thought it maybe helpful I've listed mine below for a working FZ1s, you access them by holding down Select +Reset buttons switch on the ignition, keep holding the buttons down till Di appears on the display, then hold down the buttons again for approx 2secs to access either Di or CO, there seems a bit of discussion regarding the CO values, and there significance, Regarding the Di codes foes anybody know what the a faulty injector or coil pack will return ? [table] [tr] [td] Diagnostic Codes (access press Select+Reset ->ignition ON _> press approx 8secs [/td] [td][/td] [/tr] [tr] [td]#01 – Throttle Position Sensor [/td] [td][/td] [/tr] [tr] [td]Full closed – 15-18 [/td] [td]16 [/td] [/tr] [tr] [td]Full open – 95-100 [/td] [td]96 [/td] [/tr] [tr] [td]#02 – Atmospheric Pressure Sensor (100 kPa = 29.53 inHg) [/td] [td]102 [/td] [/tr] [tr] [td]#03 – Cyl #1 Intake Air Pressure Sensor [/td] [td]102 [/td] [/tr] [tr] [td]#05 – Intake Air Temperature [/td] [td]11 [/td] [/tr] [tr] [td]#06 – Coolant Temperature [/td] [td]10 [/td] [/tr] [tr] [td]#07 – Vehicle Speed [/td] [td]0 [/td] [/tr] [tr] [td]#08 – Lean Angle Sensor [/td] [td]0.6 [/td] [/tr] [tr] [td]#09 – Fuel System Voltage [/td] [td]11.4 [/td] [/tr] [tr] [td]#20 off off (side stand) on [/td] [td]ON [/td] [/tr] [tr] [td]#21 off off ( neutral) on [/td] [td]ON [/td] [/tr] [tr] [td]#30 -> Coil #1 [/td] [td]0 [/td] [/tr] [tr] [td]#31 -> Coil #2 [/td] [td]0 [/td] [/tr] [tr] [td]#32 -> Coil #3 [/td] [td]0 [/td] [/tr] [tr] [td]#33 -> Coil #4 [/td] [td]0 [/td] [/tr] [tr] [td]#36 -> Injector #1 [/td] [td]0 [/td] [/tr] [tr] [td]#37 -> Injector #2 [/td] [td]0 [/td] [/tr] [tr] [td]#38 -> Injector #3 [/td] [td]0 [/td] [/tr] [tr] [td]#39 -> Injector #4 [/td] [td]0 [/td] [/tr] [tr] [td]#48 -> Air Induction Sys [/td] [td]0 [/td] [/tr] [tr] [td]#50 -> Fuel Injection Sys [/td] [td]0 [/td] [/tr] [tr] [td]#51 -> Radiator Fan Relay [/td] [td]0 [/td] [/tr] [tr] [td]#52 -> Headlight Relay [/td] [td]0 [/td] [/tr] [tr] [td]#53 -> EXUP Servo motor [/td] [td]0 [/td] [/tr] [tr] [td]#56 -> Sub Throttle Servo [/td] [td]0 [/td] [/tr] [tr] [td]#60 -> EEPROM Fault (Cylinder Number 01-04) [/td] [td]0 [/td] [/tr] [tr] [td]#61 -> Malfunction history code. Fault Codes 11-50 [/td] [td]0 [/td] [/tr] [tr] [td]#62 -> Malfunction history code erasure. Fault Codes 01-28 [/td] [td]0 [/td] [/tr] [tr] [td]#63 -> Malfunction code reinstate [/td] [td]0 [/td] [/tr] [tr] [td]#70 -> Control number [/td] [td]0 [/td] [/tr] [tr] [td]and the values for Co [/td] [td][/td] [/tr] [tr] [td]C:01 -5 [/td] [td]-5 [/td] [/tr] [tr] [td]C:02 20 [/td] [td]20 [/td] [/tr] [tr] [td]C:03 20 [/td] [td]20 [/td] [/tr] [tr] [td]C:04 2 [/td] [td]2 [/td] [/tr] [/table] |
