How to: heated grips - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: How to: heated grips (/showthread.php?tid=61349) |
How to: heated grips - alexanderfitu - 01-01-13 I know there are a couple of heated grip fitting guides on here, I have just fitted mine and took some pictures along the way, Hopefully its helpful to somebody. Linky http://fotifixes.com/2013/01/01/how-to-fit-heated-grips-fzs-600-fazer/ Re: How to: heated grips - xlewisbdx - 01-01-13 Thank you
Re: How to: heated grips - alexanderfitu - 01-01-13 No worries
Re: How to: heated grips - tosh23 - 09-05-13 Just marking this for my own search later...good post OP// Re: How to: heated grips - Stooby2 - 10-05-13 Can I add a point - Step1) Disconnect the battery. If you're pulling fuses out and doing all that you don't want anything live. And is that fuse part switched? If it's not you will end up with a flat battery if you forget to switch the grips off when you park up. Re: How to: heated grips - alexanderfitu - 10-05-13 yup, that fuse part is switched, thats why I went through the trouble of getting the connection from there rather than just going to the positive terminal
