1-2 gear change - Printable Version
+--- Thread: 1-2 gear change (/showthread.php?tid=61313)
Pages: 1 2
1-2 gear change - alexanderfitu - 29-12-12
Hi all
Im still getting used to my 2001 fazer, but gear changes from 1st to 2nd are clunky and occasionally crunch and doesnt engage 2nd properly.
I am pulling the clutch in all the way. My question is if this is normal, I have heard they are clunky, and if it is then im happy Smile  Keep in mind it doesnt jump out of any gears, just fails to engage 2nd sometimes.
Re: 1-2 gear change - xlewisbdx - 29-12-12
Mine gear box is very clunky. My bike loves neutral when I am pulling away, as soon as I stop it hates it Smile
Also the clunky-ness of my gearbox depends on how high I am changing gear. So If I change at 3-4k it OK  Anything higher than 5k and then it becomes clunky.
Re: 1-2 gear change - alexanderfitu - 29-12-12
Hmm yeah that is pretty much the same as my experience.
Except for neutral, neutral is easy for me to find when not moving, compared to my honda gearboxes! Smile
I suppose I should get used to it.
Re: 1-2 gear change - Fazerider - 29-12-12
Unfortunately, yes.. it is the Fazer's Achilles heel.
Something in the gearbox wasn't made quite right... whether it is the shift shaft, the selector drum profile, the selector fork or the gear itself is a mystery to me. By the time the situation gets bad enough to justify splitting the cases to examine the problem, everything has been worn by the gear getting spat out of engagement.
So long as it's only an occasional missed gear then practice and care should make it an increasingly rare event. First to second is the biggest jump in ratios in the box and it all happens much faster so it's the easiest change to cock up.
Getting the position of the gear lever right for you can make a big difference, you may find adjusting it down a couple of millimeters helps, and remember a change of footwear will probably require a re-adjustment to the lever.
Some have found fitting new springs on the shift shaft can improve things: and at least that can be done with the engine in-situ.
Re: 1-2 gear change - darrsi - 29-12-12
The clunky gear change is part of the bikes character, but that's not saying your clutch might need adjusting, or the cable is on the way out.
Try adjusting it for starters, and if it's no better, buy an original YAMAHA clutch cable, don't buy any old copy, they're nowhere near as good.
Re: 1-2 gear change - Deefer666 - 29-12-12
Every FZS600 that I have owned (a lot) has had a clunky box. Heavy duty clutch springs help a lot as does regular oil changes with quality oil. So long as it doesnt engage 2nd and then jump it's perfectly normal.... If it does engage and then jumps it points to a selector drum/fork issue.
Re: 1-2 gear change - Skippernick - 29-12-12
Sounds normal to me. The best thing i did was to concentrate on my gear changes for a couple of  long rides.
I may have a worn clutch cable as its taking me a while to get used to the clutch, I think its part of getting used to gearbox as previously mentioned. I will check the clutch cable and the lever position, thanks all.
It would also help if you removed the sprocket cover and cleaned the chain lube/road gunk out of the clutch push mechanism. I use brake cleaner for this and then once clean relube with a good quality spray grease.... This will make a big difference to the clutch.
Thats a good idea. I had the cover off recently to check the sprocket nut, so will give it a clean and re-lube.
Re: 1-2 gear change - 69oldskool - 30-12-12
Sounds normal for Yamaha, at least with the models i've owned over the years.
Just short shift when going from 1st to 2nd then you can pile it on thereafter.
Re: 1-2 gear change - taylor - 30-12-12
my bike is the same, it sounds like a shotgun loading.
Re: 1-2 gear change - limax2 - 31-12-12
(30-12-12, 10:54 PM)taylor link Wrote: my bike is the same, it sounds like a shotgun loading.
That's a good description of what mine sounds like. With practice and care it gets a bit better, but into first at standstill is always a clunk.
If it's like a shotgun "going off"  :eek  it needs sorting!
Re: 1-2 gear change - alexanderfitu - 01-01-13
Funnily Enough when I first rode my bike, I thought, this gear change sounds very rifle like! Smile As I am riding the bike I am getting more and more used to it.
Re: 1-2 gear change - Hobgoblin - 29-04-13
Hi,
My 99 FZS600 is exactly the same. 1st to 2nd at anything above 5k sounds like my wife engaging reverse gear!! It's normal for these apparently, the gearbox is just a bit rough unfortunately on these. I did oil change, clutch cable change, clean out the cable to pushrod actuator, reset and tension all to correct settings and it still does it! As the other guy said, short shift 1st to 2nd every time then give it some beans from then on!!!
Re: 1-2 gear change - alexanderfitu - 29-04-13
I gave up with trying to change it. Like you said its a characteristic of the bike. 1-2 nd at low revs and then rev out
Re: 1-2 gear change - darrsi - 29-04-13
Dare i suggest it.........try Activ8
Re: 1-2 gear change - Chris - 29-04-13
(29-04-13, 03:27 PM)darrsi link Wrote: Dare i suggest it.........try Activ8
No, you may not. Haha, never miss an opportunity with that stuff do you Darrsi  :lol  You must be on commision  :rollin
Either that or you think it really does make a difference. I've never tried it so can't comment.
Chris
(29-04-13, 03:34 PM)Chris link Wrote: [quote author=darrsi link=topic=5681.msg72524#msg72524 date=1367245669]
Chris
Well let's just put it bluntly.......i have a smooth gear change on my bike  Big Grin
:lol
