Couple of problems - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Couple of problems (/showthread.php?tid=61246) |
Couple of problems - zebadee86 - 20-12-12 Hi Guys I have owned a Fazer for almost a year and I love it. Over the last couple of days i have noticed very excessive white smoe from the exhaust even when the bike is warm, The smoke smells a bit fuelly...... This has just started suddenly and i kinda woried that it ould be serious :'( Second problem has existed since i purchased the bike The fuel gauge is constantley stuck at full exept for when the fuel light comes on the needle seems to go back to about a quater but then often goes back to full again after a while. I have no mechanicle mechanical knowledge so I am just after a bit of advice please Thanks Dave Re: Couple of problems - His Dudeness - 21-12-12 imo its probably the cold weather is causing the excessive white smoke or maybe your exhaust is collecting rain water. do you have an aftermarket exhaust? or do you leave the bike parked outside most of the time? but it could be a head gasket issue so check your oil and see if its emulsified and also check your coolant for small oily spots. Re: Couple of problems - darrsi - 21-12-12 Just a small note, you can get a build up of the mayonnaise mixture on the oil cap this time of year. When i first got the bike mine seemed to chuck a lot of white 'smoke' out of the exhaust in winter, then when i checked the oil i was horrified to see a creamy mixture on the filler cap, but was reassured that it's quite normal in winter as it's condensation mixing with the oil, especially as i was only doing 5 mile runs on it so the bike just wasn't hitting a good enough temperature to burn it off properly. I looked in the wing mirror today as well on the way home, and it looked like the bike was on a bonfire, but it's just winter doing it's thing! Re: Couple of problems - His Dudeness - 21-12-12 (21-12-12, 12:52 AM)darrsi link Wrote: Just a small note, you can get a build up of the mayonnaise mixture on the oil cap this time of year. a new o ring on the filler cap will stop that. well it did for me Re: Couple of problems - darrsi - 21-12-12 Lo and behold, i had a quick look, and sure enough there was a bit of mayo going on! On a brighter note, i found a perfect replacement 'O' ring at work. Re: Couple of problems - zebadee86 - 21-12-12 So I took the day off work to get it checked out only to be told it is normal in damp weather :o how much of a prat do I feel !!! Re: Couple of problems - darrsi - 22-12-12 You learn something new every day!
Re: Couple of problems - His Dudeness - 22-12-12 (21-12-12, 10:42 PM)zebadee86 link Wrote: So I took the day off work to get it checked out only to be told it is normal in damp weather :o how much of a prat do I feel !!! that's good news not bad :lol you're always better off getting things check if you think there's a problem |
