Braided Brake Lines - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Braided Brake Lines (/showthread.php?tid=61215) |
Braided Brake Lines - jeffco - 17-12-12 Being one of this sites more mechanically inept users I am confused by the 2 or 3 front brake line issue and would appreciate some explanation also to change the rear brake or not ? as it seems not everyone does. Re: Braided Brake Lines - wezdavo - 17-12-12 I have just put 2 piece goodrige lines on from demontweaks, £50 delivered. The oe setup is 1 line from the master cylinder which splits into 2 lines to the calipers, so thats a 3 lines kit. The 2 line kit which i have put on, is 2 lines directly from the master cylinder via a double banjo bolt (supplied) to the calipers without the need to be split. As for bleeding i found it easier to fill the lines back to front, injecting fluid up the line via the caliper bleed screw, so the air was vernted out the top through the open master cylinder.. Worked a treat [img alt= ]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img]
Re: Braided Brake Lines - jeffco - 17-12-12 Thanks
