02-03 Mk2FZS600 headlight bulb - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 02-03 Mk2FZS600 headlight bulb (/showthread.php?tid=61208) |
02-03 Mk2FZS600 headlight bulb - SteveMc278 - 16-12-12 Hi, Been advised to stick with a standard bulb, however, has anyone used a Philips X-treme Vision(+100%) for any period of time without suffering any discolouring or melting of the headlight lense unit (within the fairing housing) and without suffering any melting of electrical wiring/connectors or any other adverse affects? Thanks Re: 02-03 Mk2FZS600 headlight bulb - Fazerider - 17-12-12 Philips say those are designed for plastic lenses... the quartz envelope filters out the worst of the UV. As for heat... that's pretty much identical to an ordinary QH 55/60W bulb. Since a fraction more energy is leaving the unit as useful light rather than heat, in theory the headlight should run fractionally cooler! In short, they'll be fine. Re: 02-03 Mk2FZS600 headlight bulb - SteveMc278 - 19-12-12 Good stuff Fazerider. Thanks for the info. |
