new brake lines - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: new brake lines (/showthread.php?tid=61132) |
new brake lines - bash62 - 07-12-12 right ordered the new goodrich hoses .are my gonna have problems bleeding these .think have read that folks have problems getting the air out .any tips.ordered 2 lines from master cylinder to caliper. cheers bash Re: new brake lines - Webby62 - 28-12-12 Personally I wouldn't mess around with the brakes unless you really know what you are doing. Reliable mechanic with a brake bleeding kit would be my advice. Re: new brake lines - devilsyam - 28-12-12 first tip longer line goes to left caliper as you sit on bike remove old lines (protect paint from fluid) remount horn make small cut with stanley knife to remove rubbers that go in clips fit to new lines super glue back together connect up you will need a length silicone tube got mine from model shop and a syringe (from were ever) got mine from one them paramedic cars that packs up outside mcdonalds waiting on a call fill res with new fluid 8mm spanner open one caliper and connect tube to nipple and syringe and draw back to suck fluid you can gently squeeze lever to when fluid flows lock off remove syringe and go pump and lock to remove air stock brakes are easy 6 pots are a pig luke Re: new brake lines - dannymassive - 29-12-12 ......as above, plus, make sure brake fluid reservoir does not run low on fluid - keep it topped up! Re: new brake lines - 1967fazer - 03-01-13 If you go down the pipe and syringe route, would it not be possible just to inject fluid through the bleed nipple all the way up to the master cylinder or did I just mis read the above post and its already been said. If you don't go down the syringe route, it will take ages to bleed them, but persevere and you will get it done eventually. When doing it this way, a top tip is to get as much fluid in the system and then leave the bike over night with a cable tie around the brake lever and throttle, pulling the lever back to the bars. When you go back to the job, try also tapping the brake lines from bottom to top, to allow air to bubble up. Incidentally, as far as I'm aware you can purchase large syringes from most chemists. Hope this helps Re: new brake lines - JKay - 03-01-13 the farm supply wholesale type shops sell large syringes complete with tubing also great for filling Scott oilers Re: new brake lines - tommyteeman - 03-01-13 mityvac is good as long as you put a turn of plumbers tape on the bleed nipples threads, or it'll just suck in air. Large syringe works good too...push the fluid up from the caliper to master, will take a couple mins to do the whole job with the 2 line. With any way though you'll probably still need the loosen nipple,pull clutch in, tighten nipple repeat method to get the job right. As said tape clutch lever in overnight, should force tiny bubbles out the system |
