Misfire and Hi :) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Misfire and Hi :) (/showthread.php?tid=60947) |
Misfire and Hi :) - Hoover - 16-11-12 Hi all just joined Names Dave and I've got a 99 plate FZS600. Downside is it has developed a stutter/misfire at low revs? new plugs, new coil and is dry stored. Any ideas?? :'( Re: Misfire and Hi :) - darrsi - 16-11-12 Balance carbs for starters! http://foc-u.co.uk/index.php/topic,4730.msg40942.html#msg40942 Re: Misfire and Hi :) - AdieR - 16-11-12 What mileage is on it? Is one of your downpipes cooler than the others? Is there a pattern (eg only cold / only hot etc)? You say its dry-stored, has it stood any length of time? Did you change only one coil, or both? Blocked pilot jets aren't impossible. Re: Misfire and Hi :) - red98 - 16-11-12 so you`ve got a fazer with a stutter............perfectly normal had mine for a few years now :rollin :rollin :rollin :rollin :rollin , Re: Misfire and Hi :) - unfazed - 17-11-12 Does it happen when hot or cold or all the time? Where in the rev range does it happen? When was it last serviced? What mileage is on it? Re: Misfire and Hi :) - darrsi - 17-11-12 http://www.stutteringhelp.org/ :lol Re: Misfire and Hi :) - His Dudeness - 17-11-12 we need a bit more info. does it happen while at sea? missile misfire Re: Misfire and Hi :) - darrsi - 18-11-12 :rollin :rollin :rollin Re: Misfire and Hi :) - 98wardj - 19-11-12 had the same. check complete circuit on spark plug caps. bet one has poor resistance. replace with ngk sd05f. got mine on ebay to the door for £9 for 4. hope this helps |
