IDLE PROBLEMS - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: IDLE PROBLEMS (/showthread.php?tid=60857) |
IDLE PROBLEMS - xjrkells - 07-11-12 HI IM NEW TO THIS FORUM AND LOOKING FOR HELP WITH MY 2005 FZ1 FAZER, IT HAS RECENTLY DEVELOPED IDLING PROBLEMS .THAT WHEN YOU START THE BIKE FROM COLD THE CHOKE DOES NOT COME ON, IT IDLES AT 1000 RPM AND IF YOU GIVE IT A BIG HANDFUL OF THROTTLE IT DIES OUT. WHEN ENGINE HAS HEATED TO TEMP IT IDLES AT 1500 RPM AND DOES NOT DECREASE EVEN WHEN YOU ADJUST IDLE SCREW.I FITTED NEW PLUS AND K N AIR FILTER BUT THAT HASN'T HELPED .ANYONE ELSE COME ACROSS THIS PROBLEM OR KNOW OF A FIX MANY THANKS Re: IDLE PROBLEMS - Falcon 269 - 07-11-12 Hi and welcome. ![]() First, please turn off the caps lock on your keyboard. Thanks ... we may be old here but we ain't deaf. ![]() When you say 'choke doesn't come on', have you checked that the operating the choke lever actually moves the choke mechanism bar on the carbs? Is the lever stiff to operate? Is the cable seized or broken? These are the things I'd check first because it sounds as though your choke linkage isn't working properly. What's the mileage and recent service history of the bike? Any more mods other than the K&N filter, which won't cause this problem incidentally. Mike Re: IDLE PROBLEMS - unfazed - 07-11-12 Since it is a Gen 2 you have it is mostly likely the thermowax unit acting up. Re: IDLE PROBLEMS - Falcon 269 - 07-11-12 Fair enough. I saw 2005 and derived Gen 1 from the date. Didn't check the sidebar to see it was a Gen 2. Disregard all after 'hi' :lol Re: IDLE PROBLEMS - ghostbiker - 08-11-12 I don't know, I think its a valid post till just after the deaf. Part Mike Other than that I know less about the gen 2 than I know about the moon..... Both made of cheese right? Re: IDLE PROBLEMS - allanmac - 08-11-12 Im not sure if its the same kind of setup as the tdm900 in that when the wax melts it allows a small pin to move and reduces the fast running. On them its common for the pin to sieze in the housing so stops moving back out to the cold position so no choke or sticks in cold position and choke wont go off. Pretty easy to fix on the tdm since it was easy enough to get to. Worth checking to see if its the same fault on your gen 2. Strip the end off clean up the pin and stick it back together. Hope this is of some help. Cheers Allan Re: IDLE PROBLEMS - flesh - 08-11-12 As above it sounds like the thermowax unit. I had a similar issue with mine. I managed to sort with WD40 but often needs replaced or "stripped". Bit of a mare to get to on the FZ1 aswell as everything is in the way. Pics on the US Forum HERE or advice from DekF on this forum http://fazerowners.yuku.com/topic/31945 Re: IDLE PROBLEMS - xjrkells - 09-11-12 caps now of so no more shouting lol. where on the bike is the thermo wax thingy any pictures of it |
