DIY wheel painting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: DIY wheel painting (/showthread.php?tid=60854) |
DIY wheel painting - JayB - 07-11-12 I've realised that I can't currently afford to have my wheels powder coated Gold, especially riding with these horrible Maxxis tyres on and having a set of Pirellis waiting in the shed, so I think I am going to do a bit of DIY on my front wheel. Thinking of just giving it a good rub down and getting to work with a can of black Smoothrite. Any used that on their wheels, I don't want to do a full paint strip at this stage, so just wondering if it will adhere OK and not react with the original paint? Re: DIY wheel painting - Tmation - 07-11-12 Scuff the old wheel paint up to give a key for the new paint, degrease the surface. If you deflate the tyre you can get the masking tape on the tyre so you can paint the edge of the rim, mask up what you don't want to paint (bearings etc) and spray with some gold coloured wheel paint. Most of the stuff is a one coat job like smoothrite and fills in imperfections in the old paint surface. One plus point of this method is that if a tyre fitter scratches or marks the paint finish you can just do a bit of a respray. Oh and a cheap option as most of the cans are for four car wheels Loads of it on eBay: [size=78%]http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=gold+wheel+paint&_sacat=0&_from=R40[/size] Re: DIY wheel painting - bludclot - 07-11-12 so, you have a shed at least, that's great. i personally would leave the smoothrite in the tin... especially seeing as you're going to give it a good rub down anyway... use the 240 grit and plenty of water to rub down the edges. the rough cast centre and spokes respond to and only need a scourer to key their surfaces. mix up some filler and apply sparingly to any dents / imperfections. when dry sand again and when happy that all is smooth mask the tyre, valve and weights. (start with 1-2 inch tape lengths tucked in between the rim and tyre then double thickness newspaper around the rest of the tyre) prime any areas that have been worked on only. when dry sand with the 400 grit and some water. panel wipe the whole wheel and then colour it all over. 2 coats is enough. when dry 2 coats of lacquer is enough, i usually apply 3 for added protection and shine depth. i usually put my finished wheel in front of the lounge fire for an hour, this doesn't go down well the long haird general but does bake the paint nicely. concept chemicals primer £4 concept chemicals gloss black (or silver or gold) £4 concept chemicals acrylic lacquer £4 1/2 inch masking tape 86p p40 filler around £5 240 and 400 grit wet 'n' dry papers £1.50 panel wipe £4 i appreciate that above list will be near to £30 but it's all that you'll need to achieve a professional quality finish. the quality of the concept chemicals paint is fantastic and it's easy to apply too. i painted my van wheels with the stuff 7 years ago and there's not a single area of any of them that has failed or deteriorated in any way. well worth hunting down in your local paint factor, don't assume that halfords paint will do, it won't! here's how my rear wheel turned out: ![]() and you have the benefit of being able to touch in any future imperfections caused by tyre and balancing weight changes. hth Re: DIY wheel painting - JayB - 07-11-12 Cheers for the replies. I was thinking of a short-term fix, just for the front one, which has corroded due to the previous owner severly neglecting the bike over winter. Shed is a bit rammed but I will spray in there, though there's no heat so would need to bring indoors to cure. it's literally the inner part of the rim between the spokes. will see how time goes. I may even be a complete bandit and brush some smoothrite on there. Can do a proper job in the spring or may get them done when I take the bike off the road after christmas time. |
