Which Blow Torch? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Which Blow Torch? (/showthread.php?tid=60832) |
Which Blow Torch? - Jimmygixxer - 05-11-12 Im lookin to remove the downpipes. Id prefere to heat the nuts beforehand to try and avoid shearing a couple off. Which king of blowtorch would be best for small intricate work, powerfull enough & not cost the earth? Re: Which Blow Torch? - Dead Eye - 05-11-12 Is it not worth using a penetrating fluid first and seeing if you can get any of them off without too much hassle? Heat should work pretty well, I've just removed the downpipes and exhaust from my burnt down bike :'( and the nuts practically fell off but I wouldn't recommend subjecting your bike to a garage fire... Re: Which Blow Torch? - JZS 600 - 05-11-12 http://www.amazon.co.uk/Rothenberger-Super-Fire-Soldering-Torch/dp/B003AN9C9Y I've used these a lot at work and can say that they do the job! (good for lighting your fags off as well) Re: Which Blow Torch? - Fazerider - 05-11-12 I've used an ordinary hot air gun, on the high setting with a constricting nozzle they can get things red hot in a few minutes. Much cheaper and you don't have to store pressurised cans of flammable gas.
Re: Which Blow Torch? - JZS 600 - 05-11-12 But not so much fun! |
