need some clues please - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: need some clues please (/showthread.php?tid=60801) |
need some clues please - devilsyam - 01-11-12 me black fazers is playing up - upon pulling away it bogs till about 1500 rpm them vroom like wise at tick over rev it the revs rise then drop to below tickover then resettles i suspect carb balancing just wanted to ask for any other clues Re: need some clues please - ghostbiker - 01-11-12 Sounds a bit more than just a carb balance, but your welcome to borrow my Morgan carb balance thing. Re: need some clues please - tomlinscote - 01-11-12 It may be nothing to do with your prob but mine did the pulling away problem after I washed it thoroughly and put it away without drying it, turned out on the plug caps was not in fully and had got damp inside. Dried out properly and normal service was resumed. P Re: need some clues please - richfzs - 01-11-12 I had something sounds the same with mine 2/3 weeks back - typically, the day the girlfriend was taking her first ride out on it :rolleyes She managed ok for the day, I took it out once we got home, it still wasn't right, gave it a right good thrashing (as in red line every gear, up to about 120 - I have a private race track), and it seemed to clear it out. Dunno if it was a bit of crap in the carbs or what, and me abusing it sucked the crap through - but she said it was loads better the next day. I had been wondering if the carbs needed a balance, prior to it playing up - to the point of buying a Carbtune - but hadn't done the job yet. It remains undone Hope your fix is as simple
Re: need some clues please - Falcon 269 - 01-11-12 Is this a new problem, Luke? Was the motor running perfectly before now? What's the idle speed set at? I'd start by checking plugs, leads, caps etc. Rule out ignition-related causes as far as possible. The symptoms suggest over-rich idle fuelling (assuming it's not plugs etc). It's still on standard jetting, IIRC, but is it possible that the mixture screws have been messed with? Another possibility is that the float needle valve seat O-rings are leaking a little. Not enough to flood the carbs and cause fuel to leak from the overflows but enough to raise the fuel level in the float bowls too high. Re: need some clues please - devilsyam - 01-11-12 been there since i have owned it - ivans slip on kit - goes like a rocket it's just the very low pull away tick over is solid 1100 and always returns to this i have changed the plugs reset tps and no change it's not a misfire it's more of a cough doesent pick up low down cleanly hence i thought carb balance been a bit of a challange this un on many fronts but this is the last wee issue it's ridable just needs few more rpm's to get it rolling like you would do with a bike you have never riden before and your sussing it out Re: need some clues please - Falcon 269 - 02-11-12 Who installed the kit? Set the idle to 1250rpm - where it should be for an 'Ivanised' Gen 1 - and see what happens. Balance the carbs to eliminate that as a possibility. Re: need some clues please - devilsyam - 03-11-12 rite tried again to sort this changed plugs and air filter checked all leeds and found no fault wot i did find is you did not do the ivans kit if you recall i asked you re springs as these had been cut as per instruction and not as we do em now i checked the exup and found after reset the start point was low say 7 ok instrad 9 o clock re adjusted and after reset was fine cant increase tick over as adjuster ceased so left to soak in wd40 then the heavens opened and was game over Re: need some clues please - R1FSR - 04-11-12 Mike ...1250rpm !! ..is that not high ?...not questioning your knowledge as you know far more than me about it...just that ive always had mine around 1000 - 1100rpm mark :eek Re: need some clues please - Falcon 269 - 04-11-12 It's what Ivan recommends with his kits fitted, Paul. ![]() |
