Starter gear/clutch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Starter gear/clutch (/showthread.php?tid=60795) |
Starter gear/clutch - pointer2null - 01-11-12 Starter is starting to play up in the mornings so looks like it maybe needing attention soon. Anyone done one of these? Any tips/gotchas etc I don't think it's the motor - sounds like something jamming. Re: Starter gear/clutch - His Dudeness - 01-11-12 is it turning over slowly or is it totally locking up? Re: Starter gear/clutch - pointer2null - 01-11-12 Both, will turn slow (like battery flat) then next try will lock, repeat pressing of starting and swearing and suddenly will turn over and start as normal. Re: Starter gear/clutch - His Dudeness - 01-11-12 If the batt is definitely good I'd start with the easiest thing which is the motor itself and also check the gears that connect the motor to the engine for damage. You'd have to take off the starter clutch cover to get the motor out. You could check the bearing that's in that cover, check all the gears and then take out the two bolts that hold in the motor and check if it spins freely. If you want to take the motor apart and clean it and check it is just two more bolts. All handy stuff. If that doesn't work then maybe go on to the starter clutch. I haven't taken one out so I'd be interested in how you get on Re: Starter gear/clutch - pointer2null - 01-11-12 I'll post back when I get round to doing it - may not be for a few weeks though. Re: Starter gear/clutch - JZS 600 - 01-11-12 Silly thought, does the starter motor have brushes? |
