Seized rad guard screws....! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Seized rad guard screws....! (/showthread.php?tid=60768) |
Seized rad guard screws....! - JayB - 29-10-12 Any tips! bloody previous owner seriously neglected the bike and left it to corrode over / after winter, I am rectifying this, slowly, but I cannot remove the old rusty guard to fit the new one... :'( HELP! Do I drill them, try it with the bike hot, use a blow torch, what?! Re: Seized rad guard screws....! - Falcon 269 - 29-10-12 Centre punch and drill 'em out. That's what I had to do with mine. Then stainless fittings for a trouble-free future.
Re: Seized rad guard screws....! - MadDogMcQ - 30-10-12 I went to replace mine a few weeks ago and I thought I'd have to drill them out - they were rusty and seized solid. Before I started doing all that though, I tried my "Impact" Screwdriver with a good fitting pozi-bit. I hit the impact screwdriver as firmly as I dared with a steel hammer and to my utter amazement, they started to move. It still took a while to get them all the way out, but it did work. Now replaced with S/Steel Allen Bolts. Re: Seized rad guard screws....! - JayB - 31-10-12 Yeah, I think I will have to try an impact driver, if I can find it. Daren't move the rad too much at the mo. Gonna get some good penetrating fluid on there and try next time I'm back from a ride in daylight while it's all warmed up... Re: Seized rad guard screws....! - phil on a fazer - 31-10-12 (31-10-12, 01:45 PM)JayB link Wrote:Gonna get some good penetrating fluid on there I use Plusgas....fecking brillant. My rad screws also seized, they were allen key bolts. i cut a slot in them for a big screwdriver and used Plusgas over a few days. worked a treat
Re: Seized rad guard screws....! - red98 - 31-10-12 if you do drill the heads off you might find that the remainder of the screw comes out easy once the pressure`s off.....good luck |
