pressure plate problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: pressure plate problem (/showthread.php?tid=60727) |
pressure plate problem - bm - 25-10-12 fazer 600 t reg started the bike up ok, selected 1st gear bike conked out, thought it was the clutch stuck together, took clutch out, cleaned and oiled plates, but found the pressure plate at the rear had bits missing where the springs touch. any ideas why this would happen? where can i get a replacement pressure plate? Re: pressure plate problem - darrsi - 25-10-12 I've no idea about your biking experience so forgive me if i'm way off but did you put it into gear with the side stand down? And i don't understand why you'd oil clutch plates? Re: pressure plate problem - bm - 25-10-12 side stand was up when put into gear, clutch plates are oiled otherwise they stick to eachother Re: pressure plate problem - darrsi - 25-10-12 Okay, as you can probably tell i've never had to change a clutch before so i've learnt something new today! Re: pressure plate problem - bm - 25-10-12 think i have found the problem , its similar to thundercat engines, the presure plate can only fit one way into the basket, and take off the sprocket cover to stop the push rod from putting pressure on the clutch plates, so all i need to do is find a replacement plate, then will take photos and show here Re: pressure plate problem - darrsi - 25-10-12 http://www.yamahascooterspares.co.uk/spares/epc2.asp?modelID=9655&PageiD=16&m=YAMAHA+FZS600+Fazer+CLUTCH&uID=0 Re: pressure plate problem - bm - 25-10-12 £45 for it :eek think i could buy a complete clutch unit for that, searching continues Re: pressure plate problem - darrsi - 25-10-12 Yeah, new parts are never cheap unfortunately!! :rolleyes You could try a breakers search online, but it may be one of those parts that won't be sold seperately? Re: pressure plate problem - His Dudeness - 25-10-12 maybe someone has put stiffer springs in it. can you describe the damage a bit better? Re: pressure plate problem - Skippernick - 25-10-12 (25-10-12, 04:06 PM)darrsi link Wrote:I've no idea about your biking experience so forgive me if i'm way off but did you put it into gear with the side stand down? Its a wet clutch so it would be oiled when fired up? Re: pressure plate problem - darrsi - 25-10-12 @Skippernick, that's why i asked the question, but after a bit of research you're supposed to soak clutch plates in oil before fitting, preferably over night if possible! You live and learn.........
Re: pressure plate problem - Skippernick - 25-10-12 (25-10-12, 08:49 PM)darrsi link Wrote:@Skippernick, that's why i asked the question, but after a bit of research you're supposed to soak clutch plates in oil before fitting, preferably over night if possible! Ah i see. Was that on that you tube video that was kicking around here a while back about replacing fazer clutches i wonder? Re: pressure plate problem - darrsi - 25-10-12 No, i know the one you mean, but i've seen it mentioned in a few other places too. I've never had to change a clutch so it's it's not something i've really looked in to, to be honest. Re: pressure plate problem - unfazed - 25-10-12 Any chance you could post a picture of the part in question? Re: pressure plate problem - darrsi - 26-10-12 Look at the link i posted above and it's #7 bm, deefer666 who posts on here has a Fazer breakers yard, you could try him on 07887 854 614 Re: pressure plate problem - unfazed - 26-10-12 I was asking about a picture of the damaged part that you have. Much easier to comment on a picture as it answers a thousands questions. Refitting new plates is very easy on the fazer and you don't even have to drain the oil if you leave it on the sidestand. However the torque on the pressure plate bolts is very low 8Nm (5lbs) and easily stripped. Which is why I have always recommended beginner mechanics buy or borrow a torque spanner in the 0 to 20 Nm range, they may be close to £100 but will save a fortune in the future. Replace the springs at the same time with OEM ones. Soak the plates in engine oil over night if possible, wipe off all the excess oil before fitting and fit them in reverse order of removal. Friction plate, steel plate, damper ring and its friction plate, steel plate and so on. The pressure plate should sit flush and may need to be rotated to get it to fit correctly. As long as you have not removed anything else, then a new gasket and chek the dowels are in place and replace the cover, tighten the cover bolts in a criss cross patern to 12Nm. Check the free play at the clutch lever and the oil level (just to be sure) i and fire it up. |
