airbox removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: airbox removal (/showthread.php?tid=60713) |
airbox removal - falcomike - 24-10-12 Has anyone done away with the airbox and just fit filters straight onto the carbs? If so what size of clamp on filter did you need? Re: airbox removal - MadDogMcQ - 24-10-12 I'm guessing that would effectively weaken the mixture (certainly not something you want), so you'd be wise to adjust it accordingly as part of a Dyno-Run. Re: airbox removal - Tmation - 24-10-12 there a few kits about, http://ivansperformanceproducts.com/FZ1kit.htm scroll down the page a bit to see pictures. But read all the pages for the FZ1 (The American name for the FZS1000 or 2001-2005 bike), the pod filters offer no power gains over a correctly modified air-box and performance filter. Or another tuning place: [size=78%]http://www.holeshot.com/fz1/fz1_stage2.shtml[/size] If you like the look and the extra noise go for it. Re: airbox removal - solorider - 24-10-12 modern cv carbs dont like pod filters,they can be a nightmare to set up properly,the carbs work better with a airbox Re: airbox removal - fireblake - 25-10-12 +1 Solorider, that's what I've heard too? Re: airbox removal - devilsyam - 26-10-12 I've ran them with ivans kit did it for looks really didn't notice any difference between full monty with and without
Re: airbox removal - manuel32 - 27-10-12 It,s probably the trumpet lengths that are the important factor. Re: airbox removal - Falcon 269 - 27-10-12 It's certainly the case that without fitting correct length velocity stacks inside the pods, you will suffer low-midrange power loss over a modded airbox and K&N type filter. |
