Brake judder in the wet? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Brake judder in the wet? (/showthread.php?tid=60628) |
Brake judder in the wet? - markaboot - 14-10-12 I was riding the other night in fairly heavy rain in a 30 zone. As I pulled up to a roundabout the last 4 or 5 meters I got what I assume was brake judder. It felt like I lost a bit of braking too and had to squeeze harder. It only happened once and the bike was fine on the way home but its a little unnerving as I have never experienced it before. The last thing I want to do is go out on a Sunday ride and find I don't have brakes when I really need them. Has anyone else had this before? Anything I should be checking? Thanks Re: Brake judder in the wet? - kebab19 - 14-10-12 Judder with more effort to squeeze lever often = warped front disc. Having said that, if it was warped it should be doing that all the time from now on. May be pistons sticking in the calipers - when was the last time they were freed off? Re: Brake judder in the wet? - darrsi - 14-10-12 Doubt very much that it's a warped disc, that seems to be peoples immediate response but it's unlikely. Definitely look towards the calipers being sticky, well worth a bit of TLC if they haven't been cleaned recently. I had this issue for ages and for me it turned out to be a faulty braided brake line. But if you haven't got braided lines then there's even more of a possibility it could be standard lines expanding on braking. I wouldn't be too concerned unless it's a constant thing though! Re: Brake judder in the wet? - scottyboy2203 - 14-10-12 this may be too simple but are you sure it wasnt a lock up/re-grip moment in the wet? Ive had this before and feels like ABS but is the tyre just skipping on grippy/slippy tarmac. just a thought! Re: Brake judder in the wet? - His Dudeness - 14-10-12 could be related to the pads getting a soaking. what pads have you got? Re: Brake judder in the wet? - Jamieg285 - 15-10-12 Could it have been a bit of crap got between disc and pads, which subsequently fell out, restoring normal behaviour? Unless it does it again, I wouldn't worry about it. |
