Stainless steel exhaust header warning - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Stainless steel exhaust header warning (/showthread.php?tid=60466) |
Stainless steel exhaust header warning - Paul - 30-09-12 If you change your exhaust headers make sure the restrictor point of the new set is similar in overall opening size to the original set. The original outlet is: 35mm – 43.5mm diameter externally at its most restricted point. I’m not sure what the wall thickness is but I reckon it must be somewhere between 1.0mm and 2.00mm, my original pipes are still in good condition and I was loathe to saw them up to find out. In any event the Motad replacement header system outlet pipe is has a clear open area of 1364sqm. Whereas the original outlet is restricted to somewhere between 962sqm and 1075sqm. When I fitted the Motad headers the power band almost evaporated and a gas analyser showed it be running far too weak, this being supported by the plug colour. A further test was done by a lazer temp gauge on the exhaust clamp bracket of both original and new pipes and this showed the exhaust gas temp had risen. To solve the issue the Motad pipe was sleeved down first to 1075sqm which improved things no end, and finally down to 975sqm, which seems to be better. Plugs were checked and exhaust gas analysed and the results were as good as I could get them. However if you don’t get the right back pressure the engine will run too weak and it is possible that you may end up damaging the exhaust valve edges and seats. The photo below is the restrictor point in the original header set. Re: Stainless steel exhaust header warning - markbubble - 30-09-12 iv just fitted a used set of stainless headers(thanks to farjo) and havnt done many miles since fitted but now you ave mentioned this il take plugs out and check for colour etc,(they were new plugs aroun 800miles ago)the bike seems to run great but a little midrange has gone over the standard headers Re: Stainless steel exhaust header warning - darrsi - 01-10-12 THIS IS WORTH A READ: http://www.thumpertalk.com/topic/571594-exhaust-backpressure-the-myth/ Re: Stainless steel exhaust header warning - Paul - 01-10-12 To Darrsi I've read it...... it's a good article, but it doesn't fit with my personal experience, and so all I can say is: Sleeving down the outlet of the Motad system brought back the power band, made the plugs the right colour and dropped the exhaust gas temperature. The odd thing is you can actually see the 'pinch point' in the original exhaust system, and it's difficult to imagine Yamaha putting that in if it wasn't needed. |
